Hi, is there any plan to implement second factor selection to connect to pritunl server? For example: if the company device has yubikey installed, then to connect to the profile, I select yubikey on the client, but there is no yubikey on the home device and I would like to connect using OTP.
Thanks in advance, I would like to see such a feature. On goteleport it is implemented and I can choose the 2nd factor for connection.
