2 separate environement pritunl zero
Hello Support
Is there a way to be able to connect on 2 pritunl zero environement for users ?
exemple: we have 2 deployments pritunl zero + bastion host on 2 env (prod and staging)
those 2 env are connectable via 2 separate vpn.
each bastion host for each env need to be a different dns/ip.
Regards
Pritunl Zero hosts can be connected to the same MongoDB database the same as Pritunl VPN. Once connected to the same database both hosts can be managed from one web console.
Hello Zach
Sorry to come back late for this request.
Actually we can not establish any connection between those 2 env.
So its why i am asking if a client can connect both environnement ( with 2 different bastion / env)
Actually i have issue because when i renew key i can not connect to the other and vice versa.
It would need to have subnet matching or domain matches that don’t overlap.
