Ability to distribute profiles with client installation?
Hello!
Wondering if it’s possible to distribute the profile of a user along with the installation of the client so they don’t need to import a profile when they begin. The .conf file seems doable, but the .ovpn profile contains a private key that I assume can’t be copy/pasted everywhere. Can I generate this profile on the user’s machine once installation is complete, programmatically? If so, I can just script it, but I didn’t see anything that seemed relevant in the documentation. We’re using SSO with Google, if that matters.
Thanks!
The client command line interface documentation has more information on using the CLI. This can be used to add a profile after install. A silent install is also available with the Windows installer.
