If the route is not included or overlapped in the server routes it should not be impacted. It’s possible this is a DNS issue if the clients local DNS server has custom records for local resources. By default the Pritunl server will overwrite the clients DNS server, this can changed in the server settings.
Routes can be specifically excluded by adding the route and setting the Net Gateway option in the advanced route options. An enterprise subscription is required for this.
Hello Zach, thanks for your reply although I’m not using any custom DNS server for nodes inside the LAB, this was also an issue with custom bare bone wireguard server, but can be easily fixed by editing the config to allow non tunnelled traffic after connecting to wireguard server.
