Hi there.
I meet some issues here.
I have set up pritunl based on this doc.
I did some apt update && apt upgrade work.
At first, VPN connection works very well.
But after some hours connection, I can no longer connect with VPN anymore.
I tried to remove all the users and servers to start over again.
But the problem occurs again.
Here is the error listed on the web panel:
Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1 / time = (1674963335) Sun Jan 29 03:35:35 2023 ] – see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
TLS Error: incoming packet authentication failed from [AF_INET6]::ffff:112.64.68.154:4715
TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
TLS Error: TLS handshake failed
Do you have any ideas how to get rid of it?
Thank you!
