Is it possible to configure the Windows client so it auto-starts with Wireguard by default instead of OpenVPN?
The last method used determines what connection type will be automatically selected. Once the profile is configured as a system profile connect manually using WireGuard. The command line can also be used by running sudo pritunl-client list then sudo pritunl-client connect PROFILE_ID --mode=wg
