(IPv6 is replaced with RFC 3849 - Documentation prefix)
Client Version: v1.3.3883.60
Getting errors in my pritunl service log on my Mac M1 (ARM) not sure if it is the problem syncing the profile or the SSO when connecting…
It have this info: “dial tcp: address [[2001:db8:::2]]:443: missing port in address” but i do not understand why it have dual “[[” “]]” normally it is “just” [2001:db8:::2]:443 that is used
[2024-06-20 09:23:19][INFO] ▶ profile: Connecting ◆ device_auth=true ◆ disable_dns=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=true ◆ mode="ovpn" ◆ profile_id="<profile_id>" ◆ reconnect=true ◆ sso_auth=true
[2024-06-20 09:23:22][WARN] ▶ profile: Request ovpn connection error ◆ host="vpn.example.com"
profile: Server is offline
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).reqOvpn
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2401 +0x100f1b574
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2440 +0x100f1bc0f
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).openOvpn
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1975 +0x100f191f7
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1381 +0x100f1600b
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1364 +0x100f15e37
github.com/pritunl/pritunl-client-electron/service/profile.SyncSystemProfiles.func1
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/utils.go:413 +0x100f27493
/opt/homebrew/Cellar/go/1.22.2/libexec/src/runtime/asm_arm64.s:1222 +0x1009da303
[2024-06-20 09:23:24][WARN] ▶ profile: Request ovpn connection error ◆ host="2001:db8:::2"
profile: Request put error
Post "https://[[2001:db8:::2]]/key/ovpn_wait/<id_A>/<id_B>/<id_C>": dial tcp: address [[2001:db8:::2]]:443: missing port in address
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2365 +0x100f1b64c
/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1995 +0x100f19463
VPN node ip: 2001:db8:::2 and 192.168.1.2
vpn.example.com ip: 2001:db8:::3 192.168.1.3
