Connection problem with macos 14.7
Hi
We have problems connecting to the vpn after Mac os update to version 14.7
It take op to 30+ min to get connected status
[2024-09-17 09:37:31][INFO] ▶ profile: Connecting ◆ device_auth=true ◆ disable_dns=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=true ◆ mode="ovpn" ◆ profile_id="7ef3c6ac25c52321" ◆ reconnect=true ◆ sso_auth=true
[2024-09-17 09:37:32][ERRO] ▶ request: Bad status from server ◆ body="500: Internal Server Error" ◆ host="" ◆ status_code=500
[2024-09-17 09:37:32][WARN] ▶ profile: Request ovpn connection error ◆ host="vpn.<site>.<tdl>"
request: Bad status 500 code from server
github.com/pritunl/pritunl-client-electron/service/utils.LogRequestError
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/utils/request.go:304 +0x10070fbf3
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).reqOvpn
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2407 +0x1007df4f3
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).openOvpn
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1975 +0x1007dd1f7
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1381 +0x1007da00b
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1364 +0x1007d9e37
github.com/pritunl/pritunl-client-electron/service/profile.SyncSystemProfiles.func1
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/utils.go:413 +0x1007eb493
    /opt/homebrew/Cellar/go/1.22.2/libexec/src/runtime/asm_arm64.s:1222 +0x10029e303
[2024-09-17 09:37:33][ERRO] ▶ request: Bad status from server ◆ body="500: Internal Server Error" ◆ host="" ◆ status_code=500
[2024-09-17 09:37:33][WARN] ▶ profile: Request ovpn connection error ◆ host="vpnnode02.<site>.<tdl>"
    /Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1995 +0x1007dd463
[2024-09-17 09:39:39][WARN] ▶ profile: Request ovpn connection error ◆ host="vpnnode01.<site>.<tdl>"
profile: Single sign-on timeout
It’s an error from the Pritunl web server. Check the logs in the top right of the admin web console. If it’s a database error the logs also go to /var/log/pritunl.log when connectivity with the database is lost.
Errors only happen from users with mac OS 14.7, others do not face the same issue.
We see this error on the same time:
[xxxxx-xxxx-Node2][2024-09-18 12:55:27,636][ERROR] Exception on /key/ovpn/65b8f866482b71a658c0c0e1/65b8f868482b71a658c0c0f0/65c49451c5e1bd5e54f2308a [POST]
  File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/flask/app.py", line 2190, in wsgi_app
  File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/flask/app.py", line 1486, in full_dispatch_request
  File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/flask/app.py", line 1484, in full_dispatch_request
    rv = self.dispatch_request()
  File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/flask/app.py", line 1469, in dispatch_request
  File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/auth/app.py", line 26, in _wrapped
    return call(*args, **kwargs)
  File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/handlers/key.py", line 1773, in key_ovpn_post
    remote_addr = str(ipaddress.IPv4Address(remote_addr))
  File "/usr/lib/pritunl/usr/lib/python3.9/ipaddress.py", line 1304, in __init__
    self._ip = self._ip_int_from_string(addr_str)
  File "/usr/lib/pritunl/usr/lib/python3.9/ipaddress.py", line 1191, in _ip_int_from_string
    raise AddressValueError("Expected 4 octets in %r" % ip_str)
ipaddress.AddressValueError: Expected 4 octets in '2a03'
The clients are ipv6.
@zach
It seems to be working when you disable ipv6 on the networkcard (Network settings), then we are able to connect without any troubles.
We have two addresses on the mac, an ipv4 and ipv6:
10.100.4.54
2a03:dc80:0:f383::1a0d
Disabling the ipv6 address, seems to get pritunl to work, and we don’t receive the error posted above anymore.
So maybe either the client or server needs to be able to handle ipv6?
We are mostly running on ipv6, in our environment, so disabling ipv6 is only an temp workaround.
Also it looks to fail to lookup the Clients public IPv4 can it be related to when using “Force DNS configuration” that DNS fails to make lookup when a VPN connection is started as the DNS servers is replaced before the connection is up and running on the client.
  1. What is the lookup used for, is it when “Dynamic Client Firewall” is used?
  2. you do have app6.pritunl.com why is that not used as well for dual stack and ipv6 only clients?
[2024-09-30 12:28:53][INFO] ▶ profile: Failed to get public IPv4 address
utils: Request put error
Get "https://app4.pritunl.com/ip": dial tcp: lookup app4.pritunl.com: no such host
github.com/pritunl/pritunl-client-electron/service/utils.GetPublicAddress4
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/utils/request.go:206 +0x10060b1e4
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2115 +0x1006d9e1b
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1975 +0x1006d91f7
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1381 +0x1006d600b
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1364 +0x1006d5e37
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/utils.go:413 +0x1006e7493
	/opt/homebrew/Cellar/go/1.22.2/libexec/src/runtime/asm_arm64.s:1222 +0x10019a303
[2024-09-30 12:31:20][WARN] ▶ profile: Request ovpn connection error ◆ host="vpnnode01.example.com"
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2380 +0x1006db318
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2385 +0x1006db3c7
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2440 +0x1006dbc0f
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1995 +0x1006d9463
[2024-09-30 12:31:23][INFO] ▶ profile: Disconnecting ◆ profile_id="26203d948dd14f99"
[2024-09-30 12:31:23][INFO] ▶ profile: Disconnected ◆ profile_id="26203d948dd14f99"
[2024-09-30 12:31:25][INFO] ▶ profile: Connecting ◆ device_auth=true ◆ disable_dns=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=true ◆ mode="ovpn" ◆ profile_id="26203d948dd14f99" ◆ reconnect=true ◆ sso_auth=true
[2024-09-30 12:31:35][WARN] ▶ profile: Request ovpn connection error ◆ host="vpn.example.com"
profile: Server is offline
	/Users/apple/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2401 +0x1006db574
[2024-09-30 12:32:21][INFO] ▶ utils: Refresh DNS
[2024-09-30 12:32:54][INFO] ▶ utils: Refresh DNS
The client should only query the public IP if dynamic firewall is enabled. It will also query the IPv6 address it just doesn’t log an error. The error for the IPv4 lookup is only logged it won’t prevent connecting.
For dynamic firewall the server will take the IP address given by the client from the query and also use the IP address the web request was sent from. If there isn’t an incorrectly configured load balancer the connection should still work even if the client lookup fails.
The cause of this issue is your load balancer is possibly providing an IPv6 address in a format that is causing the check in pritunl/handlers/key.py to fail. The if ':' in remote_addr: should result in the IP address being parsed with remote_addr = str(ipaddress.IPv6Address(remote_addr)).
Edit /usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/handlers/key.py and add the log message below before the IP address parsing. Both the wireguard and openvpn handlers have this code when using search either replace both or verify the correct one is replaced. Then run sudo systemctl restart pritunl and check the logs to see what is being received.
    logger.info('Remote address check', 'handlers',
        remote_addr=remote_addr,
    else:
Dynamic Client Firewall is not used on the server so a lookup should not happen then, why do it then do a lookup?
The load balancer and VPN server is both running as dual stack
It is also enabled for device authentication, I think that was done for some compatibility reasons because the device authentication was built on the dynamic firewall system and uses the same web handlers. I will test removing the lookup but with the way it is now it won’t stop a connection if it fails and that error can be ignored.
The issue in your logs is different then the errors from the original post. The profile: Single sign-on timeout error occurs after 120 seconds if the single sign-on request isn’t completed in the browser. The client sends a authentication request to a host at /key/ovpn/<org_id>/<user_id>/<server_id> that responds with a challenge that the client completes in the browser. The client sends a request to the host at /key/ovpn_wait/<org_id>/<user_id>/<server_id> waiting for the challenge to complete. It’s possible there is an issue with the host to host messaging system. This is a known issue with some versions of MongoDB 7. It should eventually show errors but it can occur with no errors logged. This would prevent the host from receiving notification of the completed challenge and it will time out. Try renaming something in the web console to trigger an event and verify it updates without needing to refresh the page. Also set the Connection Single Sign-On Domain in the top right settings to the load balancer domain. The public address of the hosts should all be the IP address of that host or a DNS record for that IP address. Load balancers should only be set in the sync address in the advanced host settings. Network load balancers on the VPN ports cannot be used.
Note: vpnnode01 is running v1.32.3805.95 that gives single sign-on timeout and vpnnode02 is running v1.32.3897.75 that give a http error 500
renaming looks to be working
Changing replica count to 1 from 2 and detaching one server managed to the the profile to sync instead of failing
Screenshot 2024-09-30 at 23.45.42
but still in the log:
[2024-09-30 23:42:04][WARN] ▶ profile: Request ovpn connection error ◆ host="vpnnode01.example.com"
and still timeout on sso
servers running on vpnnode03 do not have any problems.
Reducing the replica count to lower than the host count with a load balancer will result in attempting to connect to an offline host. It will try the next hosts if that occurs, if the host address is a load balancer address it may fail to connect even on additional attempts. This can be avoided by setting the host public address to the public IP of the host or a DNS record for that IP.
I did fix the issue with the ipaddress.AddressValueError exception in the codebase, it will be in the next release. This was caused by the IP address parsing code, it only effects the builds on the unstable repository. Downgrade the host to v1.32.3805.95 to fix that issue.
is running mongodb 6.0.17 but tried the command destroy-secondary
sudo pritunl destroy-secondary
Note: That stopped all servers unexpectedly a note on that had been nice :slight_smile:
Also did a downgrade to v1.32.3805.95 for vpnnode02 so all servers running same version now.
The hosts should be stopped when running that command.
Its running without problems now.
And the latest client update helped on some other small issues, some clients had.
