I am attempting to launch a new pritunl host in AWS and launched via autoscaling groups (exactly 1 replica). But for the most part the setup follows the installation instructions for an oracle linux host. The AMI in derived from the one identified at: Installation that then includes the scripts in this section (minus install of mongodb).
The launch-template does freeze the node-id to ensure new ASG instances look exactly like the previous ones launched by this ASG and the launch template also sets the MongoDBURI. The primary difference is that I have my mongodb cluster on different machines.
I can access the web console. But was unable to register the domain name via let’s encrypt. In diagnosing this, I found the following:
The service does not seem to open the host on port 80 to handle let’s encrypt challenges. The service is started using oracle linux systemd. In fact, due to the exception, In think it failed to finish the setup.
I have found this error displayed from pritunl logs:
File "/usr/bin/pritunl", line 33, in <module>
sys.exit(load_entry_point('pritunl==1.32.3805.95', 'console_scripts', 'pritunl')())
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/__main__.py", line 446, in main
from pritunl import setup
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/setup/__init__.py", line 2, in <module>
from pritunl.setup.clean import setup_clean
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/setup/clean.py", line 1, in <module>
from pritunl import utils
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/utils/__init__.py", line 1, in <module>
from pritunl.utils.cert import *
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/utils/cert.py", line 2, in <module>
from pritunl.utils.misc import check_output_logged, get_temp_path
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/utils/misc.py", line 4, in <module>
from pritunl import settings
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/settings/__init__.py", line 22, in <module>
sys.modules[__name__] = Settings()
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/settings/settings.py", line 24, in __init__
self._init_modules()
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/settings/settings.py", line 128, in _init_modules
group_cls.load()
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/settings/group_file.py", line 17, in load
os.chmod(self.path, 0o600)
PermissionError: [Errno 1] Operation not permitted: '/etc/pritunl.conf'
Suggesting that part of the startup script does not have priviliege to chmod the config file. But I am not sure where to look to understand what startup scripts are being run by the service.
The troubleshooting data for my installation appears as such:
sh-4.4$ pritunl version
pritunl v1.32.3805.95
sh-4.4$ printf "dh:\n" && sudo df -h
dh:
Filesystem Size Used Avail Use% Mounted on
devtmpfs 1.8G 0 1.8G 0% /dev
tmpfs 1.8G 0 1.8G 0% /dev/shm
tmpfs 1.8G 8.4M 1.8G 1% /run
tmpfs 1.8G 0 1.8G 0% /sys/fs/cgroup
/dev/nvme0n1p1 10G 5.4G 4.7G 54% /
tmpfs 357M 0 357M 0% /run/user/0
sh-4.4$ printf "free:\n" && sudo free -l -m
free:
total used free shared buff/cache available
Mem: 3567 354 2430 8 782 2985
Low: 3567 1136 2430
High: 0 0 0
Swap: 0 0 0
sh-4.4$ printf "pritunl lsof: " && sudo lsof -p `pgrep -x pritunl` | wc -l
pritunl lsof: sudo: lsof: command not found
0
sh-4.4$ printf "pritunl-web lsof: " && sudo lsof -p `pgrep -x pritunl-web` | wc -l
pritunl-web lsof: sudo: lsof: command not found
0
sh-4.4$ printf "pritunl-dns lsof: " && sudo lsof -p `pgrep -x pritunl-dns` | wc -l
pritunl-dns lsof: sudo: lsof: command not found
0
sh-4.4$ printf "pritunl limits:\n" && sudo cat /proc/`pgrep -x pritunl`/limits
pritunl limits:
Limit Soft Limit Hard Limit Units
Max cpu time unlimited unlimited seconds
Max file size unlimited unlimited bytes
Max data size unlimited unlimited bytes
Max stack size 8388608 unlimited bytes
Max core file size 0 unlimited bytes
Max resident set unlimited unlimited bytes
Max processes 14119 14119 processes
Max open files 500000 500000 files
Max locked memory 65536 65536 bytes
Max address space unlimited unlimited bytes
Max file locks unlimited unlimited locks
Max pending signals 14119 14119 signals
Max msgqueue size 819200 819200 bytes
Max nice priority 0 0
Max realtime priority 0 0
Max realtime timeout unlimited unlimited us
sh-4.4$ printf "pritunl-web limits:\n" && sudo cat /proc/`pgrep -x pritunl-web`/limits
pritunl-web limits:
sh-4.4$ printf "pritunl-dns limits:\n" && sudo cat /proc/`pgrep -x pritunl-dns`/limits
pritunl-dns limits:
cat: /proc//limits: No such file or directory
sh-4.4$ printf "limits:\n" && sudo sh -c "ulimit -Hn; ulimit -Sn"
limits:
64000
64000
sh-4.4$ sudo netstat -tulpn | grep pritunl
tcp6 0 0 :::443 :::* LISTEN 1009/pritunl-web
sh-4.4$ printf "pritunl-http:\n" && curl -I http://localhost/check
pritunl-http:
curl: (7) Failed to connect to localhost port 80: Connection refused
sh-4.4$ printf "pritunl-internal:\n" && curl -I http://localhost:9756/check
pritunl-internal:
HTTP/1.1 200 OK
Content-Type: text/html; charset=utf-8; charset=utf-8
Content-Length: 2
Cache-Control: no-cache, no-store, must-revalidate
Pragma: no-cache
Expires: 0
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Robots-Tag: noindex
Strict-Transport-Security: max-age=31536000; includeSubDomains
Date: Wed, 03 Jul 2024 11:28:49 GMT
Server:
sh-4.4$ printf "pritunl-https:\n" && curl --insecure https://localhost
pritunl-https:
<!doctype html>
<html lang=en>
<title>Redirecting...</title>
<h1>Redirecting...</h1>
<p>You should be redirected automatically to the target URL: <a href="https/localhost/login">https/localhost/login</a>. If not, click the link.
Do you have any idea on how I trace the setup being done by the systemd service to understand what privileges are required?
