Google Single Sign-On Rate Limiting
Due to rate limits on the Google Workspace API the server must be updated to Pritunl v1.32.4349.59 to correct the disconnections from Google API errors. Alternatively the hourly single sign-on re-verification can be disabled with sudo pritunl set app.sso_connection_check false. This will still perform the check when the connection is started but the checks that occur every hour during an active connection will not be performed.
Ubuntu 25.05 AppArmor Issues
The Ubuntu 25.05 AppArmor profile will prevent OpenVPN from connecting. Run sudo apparmor_parser -R /etc/apparmor.d/openvpn to disable the profile for OpenVPN. This can be reverted by running sudo apparmor_parser -a /etc/apparmor.d/openvpn.
Debugging Information
The Client Debugging and Server Debugging documentation has detailed information on debugging the software.
Downgrading Client
Previous versions of the client are available on the Pritunl GitHub Releases click Assets to expand the available packages. Information on debugging the client is available in the Client Debugging documentation.
CentOS 8 Discontinued
CentOS 8 was discontinued on December 31st, 2021 the operating system will no longer be updated. The Pritunl repositories for CentOS 8 were also discontinued. The Oracle Linux 8 repository is fully compatible with any RHEL8 distribution including CentOS 8 and AlmaLinux 8. The Oracle Linux 8 Pritunl repository can be used on CentOS 8 but in order for the system to receive updates it must be switched to Oracle Linux 8. Oracle providers a script to upgrade to Oracle Linux 8 that will convert an existing CentOS 8 system to Oracle Linux 8.
Connection MTU Issues
Some connections may have MTU issues this can be fixed by entering a lower MSS Fix value in the server settings. First test 1200 or lower to confirm that it is an MTU issue. If this fixes the connection increase the MTU in a range of 1200-1400 to find a working MTU.
Lets Encrypt Root Certificate Issue
Due to the Oct 1st expiration of the Lets Encrypt root certificate all v1.29 versions of Pritunl containing the expired certificate will no longer produce a valid certificate. Having an invalid certificate will not disrupt VPN service. The primary issue will occur when a user attempts to import a new profile to the Pritunl Client. Both the Pritunl Client and Pritunl Server need to be updating to the latest releases containing the new root certificates to fix this issue.
The issue can easily be avoided by clicking Download Profiles on the profile page then importing the tar file into the Pritunl Client by click Import Profile, this is the same profile data that would be imported with a URI. The issue can also be avoided by replacing the domain name in the URI with the IP address of the server. The client will ignore certificate validation for URI’s containing an IP address.
Ubuntu Update Issue
If Ubuntu 20.04 is configured with the Ubuntu 18.04 Pritunl repository the error ModuleNotFoundError: No module named 'encodings' will be shown when attempting to start Pritunl. This can be fixed by running the commands below to update the repository files to the correct distribution.
sudo tee /etc/apt/sources.list.d/pritunl.list << EOF
deb http://repo.pritunl.com/stable/apt focal main
sudo tee /etc/apt/sources.list.d/mongodb-org-4.4.list << EOF
deb https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.4 multiverse
wget -qO - https://www.mongodb.org/static/pgp/server-4.4.asc | sudo apt-key add -
sudo apt update
sudo apt upgrade
EPEL OpenVPN Issue
There is currently an issue with the compilation options used on the OpenVPN package in the EPEL repository. This issue will cause routing issues on some connections. To fix this issue run the command below to install the newer OpenVPN package from the Pritunl repository. This issue will only occur on UDP servers, TCP can also be used as a workaround.
The pritunl-openvpn package is only available on the Oracle Linux 7 and Oracle Linux 8 repositories and will provide the latest version of OpenVPN. These repositories can be used on any RHEL Linux distribution including CentOS.
Pritunl OpenVPN Install RHEL 7
sudo yum swap openvpn pritunl-openvpn
Pritunl OpenVPN Install RHEL 8
sudo yum --allowerasing install pritunl-openvpn
This can be reverted by running the command below.
sudo yum --allowerasing install openvpn
iOS DNS Issue
There are currently three fixes for the DNS issue on iOS.
Add the DNS server to the server routes. The default DNS server used is 8.8.8.8 add the route 8.8.8.8/32 to the server routes for this configuration.
Remove the DNS server from the settings. This will instruct the client to use their current DNS configuration. This could cause problems with some clients if that DNS configuration becomes unroutable due to the VPN routes.
Enable VPN Client DNS Mapping in the advanced server settings. This will start a DNS server on the Pritunl server that will proxy all DNS requests and will always be available to the client.
