Two days ago we purchased the Enterprise license.
I tested it on a staging server - everything worked well.
Then I clicked “Remove License” and the license was successfully deactivated.
And I’ve deleted the instance.
After that, I set up a new server and activated the license there.
However, now I see that it looks like we have two licenses.
While trying to figure out how the licensing works, I deleted the server — I thought maybe that’s how you’re supposed to “remove” a license.
As a result, I currently don’t have any running instances (they’ve all been deleted), but the management panel still shows that two licenses are active.
How can I remove them?
Could you please help me with this?
I’ll activate the license on the third (new production-ready server and in the terraform state) once I sort things out with the previous ones.
