I have a issue where my DNS server that I set on the VPN server will stick as the DNS server on my Mac clients after they have been disconnected from the VPN causing issues.
The problem occurs when the end user do not disconnect from the VPN server properly in the client and instead just closes the laptop and goes on with their day.
While I understand that this is not the correct way to disconnect from the VPN server, it will be the way end users do it most of the time no matter what you tell them.
What is the reason behind this issue, and is it something I can do on the server-side to mitigate the issue?
zach
August 23, 2022, 6:28pm
2
After the issue occurs run the commands below to get the DNS state.
sudo scutil --dns
sudo scutil
> open
> show State:/Network/Global/DNS
> show State:/Network/Pritunl/DNS
> show State:/Network/Pritunl/Restore
> quit
I also have this problem.
sudo scutil --dns
DNS configuration
resolver #1
search domain[0] : home
nameserver[0] : 10.30.0.2
flags : Request A records
reach : 0x00000002 (Reachable)
resolver #2
domain : local
options : mdns
timeout : 5
reach : 0x00000000 (Not Reachable)
order : 300000
resolver #3
domain : 254.169.in-addr.arpa
options : mdns
timeout : 5
order : 300200
resolver #4
domain : 8.e.f.ip6.arpa
options : mdns
timeout : 5
order : 300400
resolver #5
domain : 9.e.f.ip6.arpa
options : mdns
timeout : 5
order : 300600
resolver #6
domain : a.e.f.ip6.arpa
options : mdns
timeout : 5
order : 300800
resolver #7
domain : b.e.f.ip6.arpa
options : mdns
timeout : 5
order : 301000
DNS configuration (for scoped queries)
resolver #1
if_index : 6 (en0)
flags : Scoped, Request A records
sudo scutil
> open
<dictionary> {
SearchDomains : <array> {
0 : home
ServerAddresses : <array> {
0 : 10.30.0.2
__CONFIGURATION_ID__ : Default: 0
__FLAGS__ : 2
__ORDER__ : 0
No such key
No such key
> quit
This problem is haunting our Mac clients for the past year. Any advice on the solution?
zach
January 16, 2024, 8:06am
5
This should be fixed in the v1.3.3772.10 release.
