Does Pritunl-Zero bastion support timely revocation of authorization?
Hello Pritunl Team,
We have been following you for some time, does Pritunl-Zero bastion support timely revocation of authorization? How does it work? We will subscribe in the future.
The default expiration is 10 hours, this can be set in the authorities section.
Where is this setting? I can not find it in the latest pritunl-zero version.
And no “Generate Bastion Deploy Script” button on the authority settings page, where is it?
If that button is missing it likely isn’t the latest version. Check the running version in the nodes tab.
We have deployed with “Ubuntu Bionic” scripts on Ubuntu 20.04, it should be the latest version.
In the nodes tab, this version is “1.0.2341.81”, which version is the latest and how do I upgrade or redeploy to it?
The option is labeled Certificate Expire Minutes.
