Hi everyone,
I am having trouble with my Pritunl setup. Some of our clients are behind an environment that uses outbound load balancer links. I haven’t been able to find an option in the interface or the documentation to bypass specific IPs.
We use SSO login, and I am considering creating a plugin using the sso_authenticate hook to implement logic based on source IPs, adding the load balancer IPs there.
However, I wanted to check if there is an alternative or cleaner way to configure IP bypasses within the Dynamic Firewall?
Any help or guidance would be greatly appreciated.
Best regards,
Lucas
