I’ve recently rebuilt a problematic server and have built a server problematic in a different way! I activated the new server using the license key from another server we run. It activated, seemingly, fine. However, a few times a day I’ll click back into the VPN web client to check on it, and it will have reset back to a standard version. It’s also now doing this on our other server that I copied the license from.
I’ve allowed access to app.pritunl.com from our firewall, and from within the Pritunl host VM itself, can ping to app.pritunl.com no problem. Any ideas? In the web interface logs I’m getting this:
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='app.pritunl.com', port=443): Max retries exceeded with url: /subscription (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fef0c7aac70>, 'Connection to app.pritunl.com timed out. (connect timeout=20)'))
During handling of the above exception, another exception occurred:
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/subscription.py", line 44, in update
response = requests.get(
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/pritunl/usr/lib/python3.9/site-packages/requests/adapters.py", line 507, in send
raise ConnectTimeout(e, request=request)
requests.exceptions.ConnectTimeout: HTTPSConnectionPool(host='app.pritunl.com', port=443): Max retries exceeded with url: /subscription (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7fef0c7aac70>, 'Connection to app.pritunl.com timed out. (connect timeout=20)'))
