I’m getting these errors in the logs, I’m using almalinux, how can I fix it?
[undefined][2022-04-27 00:03:47,970][INFO] Starting setup server
[undefined][2022-04-27 00:03:47,974][INFO] Generating setup server ssl cert
[winter-dreams-1820][2022-04-27 00:05:15,870][INFO] Starting server
selinux_context = "system_u:system_r:pritunl_t:s0"
[winter-dreams-1820][2022-04-27 00:05:15,870][INFO] Generating server certificate...
[winter-dreams-1820][2022-04-27 00:23:37,685][WARNING] Failed to assign ip addresses to org, ip pool empty
org_id = "62686db8ae9342e772e11ab0"
[winter-dreams-1820][2022-04-27 00:41:21,966][INFO] Starting vpn server
server_id = "62687025ae9342e772e11c49"
instance_id = "62687511ae9342e772e11f52"
instances = []
instances_count = 0
route_count = 1
network = "10.10.255.0/30"
network6 = "fd00:a0af:f00::/64"
host_id = "8ad57b7d837e4bfc86605c76faf1b273"
host_address = "10.10.40.201"
host_address6 = "fe80::5054:ff:fe2f:31e5"
host_networks = ["10.10.40.0/24"]
cur_timestamp = "2022-04-26 22:41:21.965702"
libipt = false
[winter-dreams-1820][2022-04-27 00:41:22,446][ERROR] Failed to add wg interface
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/server/instance.py", line 1326, in start_wg
'type', 'wireguard',
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/utils/misc.py", line 219, in check_output_logged
return_code, cmd, output=stdoutdata)
subprocess.CalledProcessError: Command '['ip', 'link', 'add', 'dev', 'wg0', 'type', 'wireguard']' returned non-zero exit status 2.
[winter-dreams-1820][2022-04-27 00:41:22,447][ERROR] Popen returned error exit code
cmd = ["ip", "link", "add", "dev", "wg0", "type", "wireguard"]
return_code = 2
Process stderr:
Error: Unknown device type.
File "/usr/lib64/python3.6/threading.py", line 887, in _bootstrap
self._bootstrap_inner()
File "/usr/lib64/python3.6/threading.py", line 919, in _bootstrap_inner
self.run()
File "/usr/lib64/python3.6/threading.py", line 867, in run
self._target(*self._args, **self._kwargs)
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/server/instance.py", line 1661, in _run_thread
self.start_wg()
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/utils/misc.py", line 215, in check_output_logged
stderr=stderrdata,
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/logger/__init__.py", line 55, in error
kwargs['traceback'] = traceback.format_stack()
[winter-dreams-1820][2022-04-27 00:41:22,447][ERROR] Server error occurred while running
self.start_wg()
[winter-dreams-1820][2022-04-27 00:41:22,648][ERROR] Failed to stop wg interface
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/server/instance.py", line 1404, in stop_wg
'set', self.interface_wg, 'down',
subprocess.CalledProcessError: Command '['ip', 'link', 'set', 'wg0', 'down']' returned non-zero exit status 1.
[winter-dreams-1820][2022-04-27 00:41:22,648][ERROR] Popen returned error exit code
cmd = ["ip", "link", "set", "wg0", "down"]
return_code = 1
Process stderr:
Cannot find device "wg0"
self.run()
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/server/instance.py", line 1823, in _run_thread
self.stop_wg()
stderr=stderrdata,
[winter-dreams-1820][2022-04-27 00:41:22,658][ERROR] Failed to del wg interface
File "/usr/lib/pritunl/lib/python3.6/site-packages/pritunl/server/instance.py", line 1414, in stop_wg
'del', 'dev', self.interface_wg,
subprocess.CalledProcessError: Command '['ip', 'link', 'del', 'dev', 'wg0']' returned non-zero exit status 1.
[winter-dreams-1820][2022-04-27 00:41:22,660][ERROR] Popen returned error exit code
cmd = ["ip", "link", "del", "dev", "wg0"]
