I was disable login using user pass for admin, and only allow via google sso.
but now i have error when login via sso
500 internal server error
Run sudo pritunl reset-password if there are polices preventing login run sudo pritunl disable-policies. This will only disable the polices the other settings will not change. If it’s an issue with the host configuration the ID in /etc/pritunl-zero.json will need to be cleared then run sudo systemctl restart pritunl-zero. This will create a new host with default settings the old host will be shown in the web console and the settings can be copied to the new one.
