Hi!
I have encountered an error that happened after long time when Pritunl ran without restart: OpenVPN did not start and there were many errors in /var/log/pritunl.log:
[pritunl.<domain.tld-removed>][2022-05-11 08:56:32,820][ERROR] Exception on /event/627b4c26962f9e57323bd325 [GET]
File "/usr/lib/pritunl/lib/python3.8/site-packages/flask/app.py", line 2073, in wsgi_app
File "/usr/lib/pritunl/lib/python3.8/site-packages/flask/app.py", line 1518, in full_dispatch_request
File "/usr/lib/pritunl/lib/python3.8/site-packages/flask/app.py", line 1516, in full_dispatch_request
rv = self.dispatch_request()
File "/usr/lib/pritunl/lib/python3.8/site-packages/flask/app.py", line 1502, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**req.view_args)
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/auth/app.py", line 7, in _wrapped
if not check_session(True):
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/auth/administrator.py", line 449, in check_session
admin_id = database.ParseObjectId(admin_id)
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/database/utils.py", line 30, in ParseObjectId
return bson.ObjectId(str(oid))
File "/usr/lib/pritunl/lib/python3.8/site-packages/bson/objectid.py", line 110, in __init__
self.__validate(oid)
File "/usr/lib/pritunl/lib/python3.8/site-packages/bson/objectid.py", line 213, in __validate
_raise_invalid_id(oid)
File "/usr/lib/pritunl/lib/python3.8/site-packages/bson/objectid.py", line 38, in _raise_invalid_id
raise InvalidId(
bson.errors.InvalidId: "b'6078da2dd3d212408eeb9d32'" is not a valid ObjectId, it must be a 12-byte input or a 24-character hex string
I don’t know the entire history of the server but now it is Ubuntu Focal that runs unattended updates and uses the recommended repos:
$ cat /etc/apt/sources.list.d/*
deb [ arch=amd64,arm64 ] https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/4.4 multiverse
deb http://repo.pritunl.com/stable/apt focal main
And I tried to run apt-get update && apt-get dist-upgrade and reboot the server, but it didn’t make any difference.
The exception repeated every few seconds, the OpenVPN server was down and it was not caused by a web interface, but I tried to clear cookies in web browser as suggested here Cannot access web UI .
I also tried running pritunl repair-database but it didn’t help either.
In the end I hacked the pritunl/utils/filter.py to tranlate the byte array to string:
--- /usr/lib/pritunl/lib/python3.8/site-packages/pritunl/utils/filter.py-orig 2022-05-11 09:23:02.596792240 +0000
+++ /usr/lib/pritunl/lib/python3.8/site-packages/pritunl/utils/filter.py 2022-05-11 09:26:32.662389167 +0000
@@ -57,4 +57,7 @@
def session_opt_str(key):
val = flask.session.get(key)
+ if isinstance(val, bytes):
+ print(f"WARN: session_opt_str fixup hit for key {key}")
+ return val.decode()
return None if val is None else str(val)
and the error disappeared. In fact the fixup was needed only once, after restarting Pritunl and restoring the original file it does not happen anymore.
Btw. the ID was the only one document in mongo.administrators collection. It seems that the OpenVPN startup uses some cached API call that contained bytes instead of string?
