I need to be able to report on VPN connections via a 3rd party tool. From this solution, I have the ability to link via SNMP… There might be other import options as well. Is there a solution in Pritunl to export data to an external system?
The plugin system provides functions for connection events. The auditing journal also provides connection events in json format. Both of these features require an enterprise subscription.
