After import profile, enter a password, program always say “Failed to authenticate to gw”, in this time, standart VPN in windows (using adress, login and password) works fine. I literaly did evrything what i knew. One time its was working, on windows 10, but then i install offical update, then its stop working (delete update dosnt help)
- I was try use Pritunl on Windows 8.1 and windows 10 and windows 11.
- Disable my windows defender and firewall
- Install all drivers and officel update
- Delete Adapter Wan Miniport from IKEV2 to SSTP
- Use another wifi-router and internet provider
- Download old version Pritunl
I
There is a Service log
[2023-05-01 23:05:52][INFO] ▶ main: Service starting ◆ version="1.3.3484.2"
[2023-05-01 23:06:36][INFO] ▶ profile: Connecting ◆ device_auth=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=false ◆ mode="ovpn" ◆ profile_id="c416b1164e20e925" ◆ reconnect=true ◆ sso_auth=false
[2023-05-01 23:06:47][INFO] ▶ profile: Disconnecting ◆ profile_id="c416b1164e20e925"
[2023-05-01 23:06:58][INFO] ▶ profile: Disconnected ◆ profile_id="c416b1164e20e925"
[2023-05-01 23:09:05][INFO] ▶ profile: Connecting ◆ device_auth=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=false ◆ mode="ovpn" ◆ profile_id="c416b1164e20e925" ◆ reconnect=true ◆ sso_auth=false
[2023-05-01 23:09:13][INFO] ▶ profile: Disconnecting ◆ profile_id="c416b1164e20e925"
[2023-05-01 23:09:25][INFO] ▶ profile: Disconnected ◆ profile_id="c416b1164e20e925"
[2023-05-01 23:15:48][INFO] ▶ profile: Connecting ◆ device_auth=false ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ force_dns=false ◆ mode="ovpn" ◆ profile_id="c416b1164e20e925" ◆ reconnect=true ◆ sso_auth=false
[2023-05-01 23:15:56][INFO] ▶ profile: Disconnecting ◆ profile_id="c416b1164e20e925"
[2023-05-01 23:16:08][INFO] ▶ profile: Disconnected ◆ profile_id="c416b1164e20e925"
Client Log
[2023-5-1 23:6:35][ERROR] Request: Timeout error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
RequestError: Request: Timeout error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
at Request_Request.parseError (file:///C:/Program%20Files%20(x86)/Pritunl/resources/app.asar/dist/static/app.9a8b37.js:58648:16)
at ClientRequest.<anonymous> (file:///C:/Program%20Files%20(x86)/Pritunl/resources/app.asar/dist/static/app.9a8b37.js:58688:36)
at ClientRequest.emit (node:events:513:28)
at TLSSocket.emitRequestTimeout (node:_http_client:814:9)
at Object.onceWrapper (node:events:627:28)
at TLSSocket.emit (node:events:525:35)
at Socket._onTimeout (node:net:526:8)
at listOnTimeout (node:internal/timers:559:17)
at process.processTimers (node:internal/timers:502:7)
[2023-5-1 23:6:35][ERROR] Request: Client error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
[2023-5-1 23:6:35][ERROR] Profiles: Failed to sync profile configuration
[2023-5-1 23:6:36][INFO] Profiles: Updating profile 'c416b1164e20e925'
[2023-5-1 23:9:2][ERROR] Request: Timeout error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
[2023-5-1 23:9:2][ERROR] Request: Client error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
[2023-5-1 23:9:2][ERROR] Profiles: Failed to sync profile configuration
[2023-5-1 23:9:5][INFO] Profiles: Updating profile 'c416b1164e20e925'
[2023-5-1 23:15:30][ERROR] Request: Timeout error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
[2023-5-1 23:15:30][ERROR] Request: Client error ssl=true hostname=95.67.28.82 port=444 method=GET path=/key/sync/62ff3298a0acded49f758e0a/633468730e6aad42ab78d276/62ff9f8cd1793fe79f5a53f3/24d07e5c935d1689470e57fdc9c7c102 ttl=5000
[2023-5-1 23:15:30][ERROR] Profiles: Failed to sync profile configuration
[2023-5-1 23:15:48][INFO] Profiles: Updating profile 'c416b1164e20e925'
Profile log
2023-05-01 23:06:39 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set./n
2023-05-01 23:06:39 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning./n
2023-05-01 23:06:39 OpenVPN 2.5.6 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Mar 16 2022/n
2023-05-01 23:06:39 Windows version 10.0 (Windows 10 or greater) 64bit/n
2023-05-01 23:06:39 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10/n
2023-05-01 23:06:39 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication/n
2023-05-01 23:06:39 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication/n
2023-05-01 23:06:39 TCP/UDP: Preserving recently used remote address: [AF_INET]95.67.28.82:13221/n
2023-05-01 23:06:39 UDP link local: (not bound)/n
2023-05-01 23:06:39 UDP link remote: [AF_INET]95.67.28.82:13221/n
2023-05-01 23:06:39 VERIFY OK: depth=1, O=62ff3298a0acded49f758e0a, CN=62ff3298a0acded49f758e0e/n
2023-05-01 23:06:39 VERIFY KU OK/n
2023-05-01 23:06:39 Validating certificate extended key usage/n
2023-05-01 23:06:39 NOTE: --mute triggered.../n
2023-05-01 23:06:39 4 variation(s) on previous 3 message(s) suppressed by --mute/n
2023-05-01 23:06:39 [62ff3299a0acded49f758e1b] Peer Connection Initiated with [AF_INET]95.67.28.82:13221/n
2023-05-01 23:06:40 AUTH: Received control message: AUTH_FAILED/n
2023-05-01 23:06:40 SIGTERM[soft,auth-failure] received, process exiting/n
2023-05-01 23:09:05 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set./n
2023-05-01 23:09:05 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning./n
2023-05-01 23:09:05 OpenVPN 2.5.6 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Mar 16 2022/n
2023-05-01 23:09:05 Windows version 10.0 (Windows 10 or greater) 64bit/n
2023-05-01 23:09:05 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10/n
2023-05-01 23:09:05 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication/n
2023-05-01 23:09:05 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication/n
2023-05-01 23:09:05 TCP/UDP: Preserving recently used remote address: [AF_INET]95.67.28.82:13221/n
2023-05-01 23:09:05 UDP link local: (not bound)/n
2023-05-01 23:09:05 UDP link remote: [AF_INET]95.67.28.82:13221/n
2023-05-01 23:09:05 VERIFY OK: depth=1, O=62ff3298a0acded49f758e0a, CN=62ff3298a0acded49f758e0e/n
2023-05-01 23:09:05 VERIFY KU OK/n
2023-05-01 23:09:05 Validating certificate extended key usage/n
2023-05-01 23:09:05 NOTE: --mute triggered.../n
2023-05-01 23:09:05 4 variation(s) on previous 3 message(s) suppressed by --mute/n
2023-05-01 23:09:05 [62ff3299a0acded49f758e1b] Peer Connection Initiated with [AF_INET]95.67.28.82:13221/n
2023-05-01 23:09:06 AUTH: Received control message: AUTH_FAILED/n
2023-05-01 23:09:06 SIGTERM[soft,auth-failure] received, process exiting/n
2023-05-01 23:15:48 WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set./n
2023-05-01 23:15:48 DEPRECATED OPTION: --cipher set to 'AES-128-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-128-CBC' to --data-ciphers or change --cipher 'AES-128-CBC' to --data-ciphers-fallback 'AES-128-CBC' to silence this warning./n
2023-05-01 23:15:48 OpenVPN 2.5.6 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Mar 16 2022/n
2023-05-01 23:15:48 Windows version 10.0 (Windows 10 or greater) 64bit/n
2023-05-01 23:15:48 library versions: OpenSSL 1.1.1n 15 Mar 2022, LZO 2.10/n
2023-05-01 23:15:48 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication/n
2023-05-01 23:15:48 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication/n
2023-05-01 23:15:48 TCP/UDP: Preserving recently used remote address: [AF_INET]95.67.28.82:13221/n
2023-05-01 23:15:48 UDP link local: (not bound)/n
2023-05-01 23:15:48 UDP link remote: [AF_INET]95.67.28.82:13221/n
2023-05-01 23:15:48 VERIFY OK: depth=1, O=62ff3298a0acded49f758e0a, CN=62ff3298a0acded49f758e0e/n
2023-05-01 23:15:48 VERIFY KU OK/n
2023-05-01 23:15:48 Validating certificate extended key usage/n
2023-05-01 23:15:48 NOTE: --mute triggered.../n
2023-05-01 23:15:48 4 variation(s) on previous 3 message(s) suppressed by --mute/n
2023-05-01 23:15:48 [62ff3299a0acded49f758e1b] Peer Connection Initiated with [AF_INET]95.67.28.82:13221/n
2023-05-01 23:15:49 AUTH: Received control message: AUTH_FAILED/n
2023-05-01 23:15:49 SIGTERM[soft,auth-failure] received, process exiting/n
