When using the Pritunl Client and the option to import profiles using the URI, the input allows for an invalid url.
Specifically, causing an issue with some clumsy copy+pasters, is it allows a URI that starts with " " aka %20. Doing so also changes the “port” to 443 instead of the actual port (not that it would ever connect, but it’s still odd).
pritunl://vpn.example.com:5056/ku/X4xKFNTZ
While troubleshooting an import, I noticed in the log:
[2024-7-23 11:20:34][ERROR] Request: Client error ssl=true hostname=%20pritunl port=443 method=GET path=//vpn.example.com:5056/ku/X4xKFNTZ ttl=12000
As a domain should never start with a space, I believe a sanity check should be added to prevent the invalid entry with an error prior to pressing import or prior to closing the import window.
