Geographically distributed connection
Hello!
I am interested in the possibility of geographically separated nodes with a common address. Is it possible to do this?
for example, the general address of access.store.tech. and if users are in Europe, they are connected to a node in Europe, with, for example, the address vpn01.store.tech, and if in Africa, then to a node in Africa with the address vpn02.store.tech
This can be done automatically with the Geo Sort Host Selection option in the server settings. Configure all the hosts with the public address set to the address of the server, not a load balancer. Add all the hosts to one server and set the replication count equal to the host count. The client will then use lookup each host with a GeoIP database to connect to the closest host.
is it available without a premium subscription?
That feature requires an enterprise subscription.
