Getting failed to check elastic index after adding ELK information in the setting
search: Failed to check elastic index
cannot retrieve information from OpenSearch
github.com/pritunl/pritunl-zero/search.(*Client).CreateIndex
Pritunl Zero is tested with OpenSearch v1.3.2, this error is likely caused by a firewall or authentication issue. Below is the configuration used for the OpenSearch test server.
# setup
sudo dnf -y update
sudo dnf -y install dnf-automatic
sudo sed -i 's/^upgrade_type =.*/upgrade_type = default/g' /etc/dnf/automatic.conf
sudo sed -i 's/^download_updates =.*/download_updates = yes/g' /etc/dnf/automatic.conf
sudo sed -i 's/^apply_updates =.*/apply_updates = yes/g' /etc/dnf/automatic.conf
sudo systemctl enable --now dnf-automatic.timer
sudo tee /etc/security/limits.conf << EOF
* hard nofile 500000
* soft nofile 500000
root hard nofile 500000
root soft nofile 500000
sudo tee /etc/sysctl.d/10-maxmap.conf << EOF
vm.max_map_count=262144
sudo sysctl -w vm.max_map_count=262144
# gpg
wget https://artifacts.opensearch.org/publickeys/opensearch.pgp
gpg --import opensearch.pgp
rm opensearch.pgp
gpg --edit-key C5B7498965EFD1C2924BA9D539D319879310D3FC
trust
5
quit
# opensearch
wget https://artifacts.opensearch.org/releases/bundle/opensearch/1.3.2/opensearch-1.3.2-linux-x64.tar.gz
wget https://artifacts.opensearch.org/releases/bundle/opensearch/1.3.2/opensearch-1.3.2-linux-x64.tar.gz.sig
gpg --verify opensearch-1.3.2-linux-x64.tar.gz.sig opensearch-1.3.2-linux-x64.tar.gz
sudo useradd opensearch
sudo mkdir /var/lib/opensearch
sudo mkdir /var/log/opensearch
sudo chown opensearch:opensearch /var/lib/opensearch
sudo chown opensearch:opensearch /var/log/opensearch
sudo systemctl stop opensearch
sudo systemctl stop opensearch-dashboards
tar xf opensearch-1.3.2-linux-x64.tar.gz
sudo rm -rf /usr/local/opensearch-orig
sudo mv /usr/local/opensearch /usr/local/opensearch-orig
sudo mv opensearch-1.3.2 /usr/local/opensearch
sudo chown -R opensearch:opensearch /usr/local/opensearch
sudo sed -i 's/^-Xms.*/-Xms9g/g' /usr/local/opensearch/config/jvm.options
sudo sed -i 's/^-Xmx.*/-Xmx9g/g' /usr/local/opensearch/config/jvm.options
sudo sed -i 's/^  reserved:.*/  reserved: false/g' /usr/local/opensearch/plugins/opensearch-security/securityconfig/internal_users.yml
sudo -u opensearch -g opensearch /usr/local/opensearch/opensearch-tar-install.sh -Ecluster.name=silicon.red -Enode.name=opensearch1 -Ehttp.host=0.0.0.0 -Ediscovery.type=single-node -Epath.data=/var/lib/opensearch -Epath.logs=/var/log/opensearch
sudo tee /etc/systemd/system/opensearch.service << EOF
[Unit]
Description=Opensearch
[Service]
User=opensearch
Group=opensearch
WorkingDirectory=/usr/local/opensearch
ExecStart=/bin/bash /usr/local/opensearch/opensearch-tar-install.sh -Ecluster.name=silicon.red -Enode.name=opensearch1 -Ehttp.host=0.0.0.0 -Ediscovery.type=single-node -Epath.data=/var/lib/opensearch -Epath.logs=/var/log/opensearch
[Install]
WantedBy=multi-user.target
sudo systemctl daemon-reload
sudo systemctl enable opensearch
sudo systemctl restart opensearch
curl -XGET --insecure -u 'admin:admin' 'https://localhost:9200'
# opensearch auth
sudo -u opensearch -g opensearch JAVA_HOME=/usr/local/opensearch/jdk sh /usr/local/opensearch/plugins/opensearch-security/tools/hash.sh
sudo -u opensearch -g opensearch JAVA_HOME=/usr/local/opensearch/jdk /usr/local/opensearch/plugins/opensearch-security/tools/securityadmin.sh -cd "/usr/local/opensearch/plugins/opensearch-security/securityconfig" -icl -key "/usr/local/opensearch/config/kirk-key.pem" -cert "/usr/local/opensearch/config/kirk.pem" -cacert "/usr/local/opensearch/config/root-ca.pem" -
# opensearch dashboard
wget https://artifacts.opensearch.org/releases/bundle/opensearch-dashboards/1.3.2/opensearch-dashboards-1.3.2-linux-x64.tar.gz
wget https://artifacts.opensearch.org/releases/bundle/opensearch-dashboards/1.3.2/opensearch-dashboards-1.3.2-linux-x64.tar.gz.sig
gpg --verify opensearch-dashboards-1.3.2-linux-x64.tar.gz.sig opensearch-dashboards-1.3.2-linux-x64.tar.gz
tar xf opensearch-dashboards-1.3.2-linux-x64.tar.gz
sudo rm -rf /usr/local/opensearch-dashboards-orig
sudo mv /usr/local/opensearch-dashboards /usr/local/opensearch-dashboards-orig
sudo mv opensearch-dashboards-1.3.2 /usr/local/opensearch-dashboards
sudo chown -R opensearch:opensearch /usr/local/opensearch-dashboards
sudo sed -i 's/^opensearch.password:.*/opensearch.password: "####kibanaserver_password####"/g' /usr/local/opensearch-dashboards/config/opensearch_dashboards.yml
sudo -u opensearch -g opensearch /usr/local/opensearch-dashboards/bin/opensearch-dashboards -H 0.0.0.0
sudo tee /etc/systemd/system/opensearch-dashboards.service << EOF
[Unit]
Description=Opensearch Dashboards
[Service]
User=opensearch
Group=opensearch
WorkingDirectory=/usr/local/opensearch-dashboards
ExecStart=/bin/sh /usr/local/opensearch-dashboards/bin/opensearch-dashboards -H 0.0.0.0
[Install]
sudo systemctl enable opensearch-dashboards
sudo systemctl restart opensearch-dashboards
