Help to build arm client
Hi
Is it possible to give me some pointers on how to build the linux arm64 client?
J
The build specs for the GUI client is at pritunl-pacur/pritunl-client-electron/PKGBUILD and for the CLI client at pritunl-pacur/pritunl-client/PKGBUILD.
Thanks, I had seen that file but no idea what it means?
Do I just install the depends for say apt if I am on ubuntu/debian, then run the commands in build:apt section?
Those are the scripts used to build the client with the custom build system pacur. The CLI client only requires go and can be installed with the commands below. The pritunl-client-electron repository repository has the systemd file for the background service.
go install github.com/pritunl/pritunl-client-electron/cli@latest
go install github.com/pritunl/pritunl-client-electron/service@latest
sudo cp ~/go/bin/service /usr/bin/pritunl-client-service
sudo cp ~/go/bin/cli /usr/bin/pritunl-client
