How to setup?
- Pritunl Zero high availability to increase redundancy and fail over?
- Increase scalability
How to setup?
It is the same design as the Pritunl VPN server. Each host just needs to connect to the same MongoDB database, this can be configured in /etc/pritunl-zero.json. If multiple Pritunl Zero nodes are put in front of a load balancer the Forwarded for header and Forwarded proto header options should be configured in the node settings.
