How to block client-to-client traffic on the same VPN server (Virtual Network)?
I am running into a security concern related to client-to-client communication on a Pritunl VPN server and would appreciate guidance on the correct or recommended approach.
Scenario:
  • Office machines are connected to a Pritunl VPN server.
  • A user connects to the same VPN server from home.
  • Because both clients are on the same Virtual Network, the home client can directly access office machines via their VPN IP addresses.
  • This behavior violates our internal security policy, as VPN users should only access internal services, not other client endpoints.
Current understanding:
  • This seems to be caused by routing within the Virtual Network (client-to-client traffic being allowed).
  • Disabling Multiple Devices partially mitigates this, but it is not ideal, as the feature is still useful for other legitimate cases.
Questions:
  1. Is there an official or recommended way in Pritunl to block client-to-client traffic on the same VPN server?
  2. Can this be enforced via:
    • Firewall rules
    • Server settings
    • Organization settings
    • Or any undocumented / advanced configuration?
  3. Is there a way to allow access only to specific internal subnets while explicitly preventing traffic between VPN clients?
You can disable connections between clients by turning off the “Inter-Client Routing” option in the VPN server settings. I would also recommend enabling “Restrict Routing” for better isolation.
You simply need to add the specific networks you want clients to access under the server’s Routes tab. Routes | Pritunl VPN | Pritunl Documentation
I highly recommend avoiding the default route 0.0.0.0/0 if the VPN is used strictly for private network access - especially if your Pritunl instance is hosted in the cloud.
There isn’t any option to disable client-to-client routing. It is difficult to do without breaking other functionality. The Inter-Client Routing option is specifically for disabling the client routes created for replicated servers. This allows client traffic to move between hosts running a replicated server.
Understood. In that scenario, another workaround would be to enforce firewall rules on the client side.
