I know that Pritunl has its own VPN client but is it possible to use a different Wireguard VPN Client and how to find the configuration for each user?
In the UI i don’t see a way to download the config. It would be nice if that’s possible.
The idea is that If I use the official Wireguard VPN Client for other VPN connections and it would be nice if i can use the same also with Pritunl without installing new application.
Pritunl has additional authentication and connection management for WireGuard connections that is only available in the Pritunl client. A temporary WireGuard key is generated for each connection and is removed when the connection ends. The WireGuard documentation section has more information.
