There’s already support for service side certificate verification using client certificates. After the authority is configured to the Client Certificate Authority in the service settings Pritunl Zero will automatically renew a certificate to use for client certificate validation. The Golang code below is an example web server with this verification.
To get verification from the Pritunl Zero server to the service server a domain can be used for the internal server address. This will require a valid HTTPS certificate on that server which can be obtain by that service with Lets Encrypt DNS verification.
sudo -u cloud mkdir -p /home/cloud/git/test-server
sudo -u cloud tee /home/cloud/git/test-server/main.go << 'EOF'
package main
import (
"bytes"
"crypto/ecdsa"
"crypto/elliptic"
"crypto/rand"
"crypto/tls"
"crypto/x509"
"crypto/x509/pkix"
"encoding/pem"
"math/big"
"net/http"
"time"
"github.com/gin-gonic/gin"
"github.com/gorilla/websocket"
const (
writeTimeout = 10 * time.Second
pingInterval = 3 * time.Second
pingWait = 10 * time.Second
const rootCa = `-----BEGIN CERTIFICATE-----
<AUTHORITY_ROOT_CERTIFICATE>
-----END CERTIFICATE-----
const indexData = `
<html>
<head>
<title>Example Internal Service</title>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport"
content="user-scalable=no, width=device-width, initial-scale=1">
<meta name="mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-capable" content="yes">
</head>
<body>
<h2>Example Internal Web Service With Proxied WebSocket</h2>
<p>Try opening in incognito window to test session</p>
<label for="ws-output">WebSocket Data</label><br/>
<textarea id="ws-output" rows="20" cols="25" readonly
style="resize: none; font-family: 'Lucida Console', Monaco, monospace; margin-bottom: 5px"></textarea><br/>
<button id="ws-send" type="button">Send Message</button>
<button id="logout" type="button">Logout</button>
<script>
let socket;
let wsOutput = document.getElementById('ws-output');
let wsSend = document.getElementById('ws-send');
function timestamp() {
let date = new Date();
return date.getHours().toString().padStart(2, '0') + ':' +
date.getMinutes().toString().padStart(2, '0') + ':' +
date.getSeconds().toString().padStart(2, '0');
function connect() {
let url = '';
let location = window.location;
if (location.protocol === 'https:') {
url += 'wss';
} else {
url += 'ws';
url += '://' + location.host + '/ws';
socket = new WebSocket(url);
socket.addEventListener('open', () => {
wsOutput.value += timestamp() + ' connected\n';
wsOutput.scrollTop = wsOutput.scrollHeight;
socket.addEventListener('close', () => {
setTimeout(() => {
connect();
}, 500);
socket.addEventListener('message', (evt) => {
wsOutput.value += timestamp() + ' recv: ' + evt.data + '\n';
connect();
wsSend.onclick = () => {
wsOutput.value += timestamp() + ' send: ping\n';
socket.send('ping');
document.getElementById('logout').onclick = () => {
window.location.href = '/logout';
</script>
</body>
</html>
var (
upgrader = websocket.Upgrader{
HandshakeTimeout: 30 * time.Second,
ReadBufferSize: 1024,
WriteBufferSize: 1024,
CheckOrigin: func(r *http.Request) bool {
return true
func indexGet(c *gin.Context) {
c.Data(200, "text/html", []byte(indexData))
func testGet(c *gin.Context) {
c.Data(200, "text/plain", []byte("test\n"))
func indexOptions(c *gin.Context) {
if c.Request.Method == http.MethodOptions {
c.Writer.Header().Set("Allow", "OPTIONS, GET, POST")
c.Writer.WriteHeader(http.StatusOK)
return
c.Writer.WriteHeader(http.StatusMethodNotAllowed)
func websocketGet(c *gin.Context) {
conn, err := upgrader.Upgrade(c.Writer, c.Request, nil)
if err != nil {
c.AbortWithError(500, err)
return
conn.SetReadDeadline(time.Now().Add(pingWait))
conn.SetPongHandler(func(x string) (err error) {
return
defer func() {
conn.Close()
go func() {
for {
msgType, msg, err := conn.ReadMessage()
if err != nil {
conn.Close()
break
if msgType == websocket.TextMessage &&
bytes.Compare(msg, []byte("ping")) == 0 {
conn.SetWriteDeadline(time.Now().Add(writeTimeout))
err = conn.WriteMessage(websocket.TextMessage, []byte("pong"))
if err != nil {
conn.Close()
break
for {
time.Sleep(pingInterval)
err = conn.WriteMessage(websocket.TextMessage, []byte("keepalive"))
if err != nil {
conn.Close()
break
err = conn.WriteControl(websocket.PingMessage, []byte{},
if err != nil {
return
func pingGet(c *gin.Context) {
c.String(200, "ok")
func selfCert(parent *x509.Certificate, parentKey *ecdsa.PrivateKey) (
cert *x509.Certificate, certByt []byte, certKey *ecdsa.PrivateKey,
err error) {
certKey, err = ecdsa.GenerateKey(
elliptic.P384(),
rand.Reader,
if err != nil {
return
serialLimit := new(big.Int).Lsh(big.NewInt(1), 128)
serial, err := rand.Int(rand.Reader, serialLimit)
if err != nil {
return
certTempl := &x509.Certificate{
SerialNumber: serial,
Subject: pkix.Name{
Organization: []string{"Pritunl Zero Test HTTP Server"},
NotBefore: time.Now().Add(-24 * time.Hour),
NotAfter: time.Now().Add(26280 * time.Hour),
KeyUsage: x509.KeyUsageKeyEncipherment |
x509.KeyUsageDigitalSignature,
ExtKeyUsage: []x509.ExtKeyUsage{x509.ExtKeyUsageServerAuth},
BasicConstraintsValid: true,
SignatureAlgorithm: x509.ECDSAWithSHA256,
if parent == nil {
parent = certTempl
parentKey = certKey
certByt, err = x509.CreateCertificate(rand.Reader, certTempl, parent,
certKey.Public(), parentKey)
if err != nil {
return
cert, err = x509.ParseCertificate(certByt)
if err != nil {
return
return
func main() {
engine := gin.New()
engine.Use(gin.Logger())
engine.GET("/", indexGet)
engine.OPTIONS("/", indexOptions)
engine.GET("/test", testGet)
engine.GET("/ws", websocketGet)
engine.GET("/ping", pingGet)
caCert, _, caKey, err := selfCert(nil, nil)
if err != nil {
panic(err)
_, certByt, certKey, err := selfCert(caCert, caKey)
if err != nil {
panic(err)
certKeyByte, err := x509.MarshalECPrivateKey(certKey)
if err != nil {
panic(err)
certKeyBlock := &pem.Block{
Type: "EC PRIVATE KEY",
Bytes: certKeyByte,
keyPem := pem.EncodeToMemory(certKeyBlock)
certBlock := &pem.Block{
Type: "CERTIFICATE",
Bytes: certByt,
certPem := pem.EncodeToMemory(certBlock)
keypair, err := tls.X509KeyPair(certPem, keyPem)
if err != nil {
return
certPool := x509.NewCertPool()
certPool.AppendCertsFromPEM([]byte(rootCa))
tlsConfig := &tls.Config{
MinVersion: tls.VersionTLS12,
MaxVersion: tls.VersionTLS13,
Certificates: []tls.Certificate{
keypair,
ClientAuth: tls.RequireAndVerifyClientCert,
ClientCAs: certPool,
listener, err := tls.Listen("tcp", ":8000", tlsConfig)
if err != nil {
panic(err)
return
server := &http.Server{
Addr: ":8000",
Handler: engine,
ReadTimeout: 10 * time.Second,
WriteTimeout: 10 * time.Second,
MaxHeaderBytes: 4096,
err = server.Serve(listener)
if err != nil {
panic(err)
sudo -u cloud tee /home/cloud/git/test-server/go.mod << 'EOF'
module github.com/pritunl/test-server
go 1.24.0
toolchain go1.24.6
require (
github.com/gin-gonic/gin v1.11.0
github.com/gorilla/websocket v1.5.3
require (
github.com/bytedance/sonic v1.14.0 // indirect
github.com/bytedance/sonic/loader v0.3.0 // indirect
github.com/cloudwego/base64x v0.1.6 // indirect
github.com/gabriel-vasile/mimetype v1.4.8 // indirect
github.com/gin-contrib/sse v1.1.0 // indirect
github.com/go-playground/locales v0.14.1 // indirect
github.com/go-playground/universal-translator v0.18.1 // indirect
github.com/go-playground/validator/v10 v10.27.0 // indirect
github.com/goccy/go-json v0.10.2 // indirect
github.com/goccy/go-yaml v1.18.0 // indirect
github.com/json-iterator/go v1.1.12 // indirect
github.com/klauspost/cpuid/v2 v2.3.0 // indirect
github.com/leodido/go-urn v1.4.0 // indirect
github.com/mattn/go-isatty v0.0.20 // indirect
github.com/modern-go/concurrent v0.0.0-20180228061459-e0a39a4cb421 // indirect
github.com/modern-go/reflect2 v1.0.2 // indirect
github.com/pelletier/go-toml/v2 v2.2.4 // indirect
github.com/quic-go/qpack v0.5.1 // indirect
github.com/quic-go/quic-go v0.54.0 // indirect
github.com/twitchyliquid64/golang-asm v0.15.1 // indirect
github.com/ugorji/go/codec v1.3.0 // indirect
go.uber.org/mock v0.5.0 // indirect
golang.org/x/arch v0.20.0 // indirect
golang.org/x/crypto v0.40.0 // indirect
golang.org/x/mod v0.25.0 // indirect
golang.org/x/net v0.42.0 // indirect
golang.org/x/sync v0.16.0 // indirect
golang.org/x/sys v0.35.0 // indirect
golang.org/x/text v0.27.0 // indirect
golang.org/x/tools v0.34.0 // indirect
google.golang.org/protobuf v1.36.9 // indirect
sudo -u cloud tee /home/cloud/git/test-server/go.sum << 'EOF'
github.com/bytedance/sonic v1.14.0 h1:/OfKt8HFw0kh2rj8N0F6C/qPGRESq0BbaNZgcNXXzQQ=
github.com/bytedance/sonic v1.14.0/go.mod h1:WoEbx8WTcFJfzCe0hbmyTGrfjt8PzNEBdxlNUO24NhA=
github.com/bytedance/sonic/loader v0.3.0 h1:dskwH8edlzNMctoruo8FPTJDF3vLtDT0sXZwvZJyqeA=
github.com/bytedance/sonic/loader v0.3.0/go.mod h1:N8A3vUdtUebEY2/VQC0MyhYeKUFosQU6FxH2JmUe6VI=
github.com/cloudwego/base64x v0.1.6 h1:t11wG9AECkCDk5fMSoxmufanudBtJ+/HemLstXDLI2M=
github.com/cloudwego/base64x v0.1.6/go.mod h1:OFcloc187FXDaYHvrNIjxSe8ncn0OOM8gEHfghB2IPU=
github.com/davecgh/go-spew v1.1.0/go.mod h1:J7Y8YcW2NihsgmVo/mv3lAwl/skON4iLHjSsI+c5H38=
github.com/davecgh/go-spew v1.1.1 h1:vj9j/u1bqnvCEfJOwUhtlOARqs3+rkHYY13jYWTU97c=
github.com/davecgh/go-spew v1.1.1/go.mod h1:J7Y8YcW2NihsgmVo/mv3lAwl/skON4iLHjSsI+c5H38=
github.com/gabriel-vasile/mimetype v1.4.8 h1:FfZ3gj38NjllZIeJAmMhr+qKL8Wu+nOoI3GqacKw1NM=
github.com/gabriel-vasile/mimetype v1.4.8/go.mod h1:ByKUIKGjh1ODkGM1asKUbQZOLGrPjydw3hYPU2YU9t8=
github.com/gin-contrib/sse v1.1.0 h1:n0w2GMuUpWDVp7qSpvze6fAu9iRxJY4Hmj6AmBOU05w=
github.com/gin-contrib/sse v1.1.0/go.mod h1:hxRZ5gVpWMT7Z0B0gSNYqqsSCNIJMjzvm6fqCz9vjwM=
github.com/gin-gonic/gin v1.11.0 h1:OW/6PLjyusp2PPXtyxKHU0RbX6I/l28FTdDlae5ueWk=
github.com/gin-gonic/gin v1.11.0/go.mod h1:+iq/FyxlGzII0KHiBGjuNn4UNENUlKbGlNmc+W50Dls=
github.com/go-playground/assert/v2 v2.2.0 h1:JvknZsQTYeFEAhQwI4qEt9cyV5ONwRHC+lYKSsYSR8s=
github.com/go-playground/assert/v2 v2.2.0/go.mod h1:VDjEfimB/XKnb+ZQfWdccd7VUvScMdVu0Titje2rxJ4=
github.com/go-playground/locales v0.14.1 h1:EWaQ/wswjilfKLTECiXz7Rh+3BjFhfDFKv/oXslEjJA=
github.com/go-playground/locales v0.14.1/go.mod h1:hxrqLVvrK65+Rwrd5Fc6F2O76J/NuW9t0sjnWqG1slY=
github.com/go-playground/universal-translator v0.18.1 h1:Bcnm0ZwsGyWbCzImXv+pAJnYK9S473LQFuzCbDbfSFY=
github.com/go-playground/universal-translator v0.18.1/go.mod h1:xekY+UJKNuX9WP91TpwSH2VMlDf28Uj24BCp08ZFTUY=
github.com/go-playground/validator/v10 v10.27.0 h1:w8+XrWVMhGkxOaaowyKH35gFydVHOvC0/uWoy2Fzwn4=
github.com/go-playground/validator/v10 v10.27.0/go.mod h1:I5QpIEbmr8On7W0TktmJAumgzX4CA1XNl4ZmDuVHKKo=
github.com/goccy/go-json v0.10.2 h1:CrxCmQqYDkv1z7lO7Wbh2HN93uovUHgrECaO5ZrCXAU=
github.com/goccy/go-json v0.10.2/go.mod h1:6MelG93GURQebXPDq3khkgXZkazVtN9CRI+MGFi0w8I=
github.com/goccy/go-yaml v1.18.0 h1:8W7wMFS12Pcas7KU+VVkaiCng+kG8QiFeFwzFb+rwuw=
github.com/goccy/go-yaml v1.18.0/go.mod h1:XBurs7gK8ATbW4ZPGKgcbrY1Br56PdM69F7LkFRi1kA=
github.com/google/go-cmp v0.7.0 h1:wk8382ETsv4JYUZwIsn6YpYiWiBsYLSJiTsyBybVuN8=
github.com/google/go-cmp v0.7.0/go.mod h1:pXiqmnSA92OHEEa9HXL2W4E7lf9JzCmGVUdgjX3N/iU=
github.com/google/gofuzz v1.0.0/go.mod h1:dBl0BpW6vV/+mYPU4Po3pmUjxk6FQPldtuIdl/M65Eg=
github.com/gorilla/websocket v1.5.3 h1:saDtZ6Pbx/0u+bgYQ3q96pZgCzfhKXGPqt7kZ72aNNg=
github.com/gorilla/websocket v1.5.3/go.mod h1:YR8l580nyteQvAITg2hZ9XVh4b55+EU/adAjf1fMHhE=
github.com/json-iterator/go v1.1.12 h1:PV8peI4a0ysnczrg+LtxykD8LfKY9ML6u2jnxaEnrnM=
github.com/json-iterator/go v1.1.12/go.mod h1:e30LSqwooZae/UwlEbR2852Gd8hjQvJoHmT4TnhNGBo=
github.com/klauspost/cpuid/v2 v2.3.0 h1:S4CRMLnYUhGeDFDqkGriYKdfoFlDnMtqTiI/sFzhA9Y=
github.com/klauspost/cpuid/v2 v2.3.0/go.mod h1:hqwkgyIinND0mEev00jJYCxPNVRVXFQeu1XKlok6oO0=
github.com/leodido/go-urn v1.4.0 h1:WT9HwE9SGECu3lg4d/dIA+jxlljEa1/ffXKmRjqdmIQ=
github.com/leodido/go-urn v1.4.0/go.mod h1:bvxc+MVxLKB4z00jd1z+Dvzr47oO32F/QSNjSBOlFxI=
github.com/mattn/go-isatty v0.0.20 h1:xfD0iDuEKnDkl03q4limB+vH+GxLEtL/jb4xVJSWWEY=
github.com/mattn/go-isatty v0.0.20/go.mod h1:W+V8PltTTMOvKvAeJH7IuucS94S2C6jfK/D7dTCTo3Y=
github.com/modern-go/concurrent v0.0.0-20180228061459-e0a39a4cb421 h1:ZqeYNhU3OHLH3mGKHDcjJRFFRrJa6eAM5H+CtDdOsPc=
github.com/modern-go/concurrent v0.0.0-20180228061459-e0a39a4cb421/go.mod h1:6dJC0mAP4ikYIbvyc7fijjWJddQyLn8Ig3JB5CqoB9Q=
github.com/modern-go/reflect2 v1.0.2 h1:xBagoLtFs94CBntxluKeaWgTMpvLxC4ur3nMaC9Gz0M=
github.com/modern-go/reflect2 v1.0.2/go.mod h1:yWuevngMOJpCy52FWWMvUC8ws7m/LJsjYzDa0/r8luk=
github.com/pelletier/go-toml/v2 v2.2.4 h1:mye9XuhQ6gvn5h28+VilKrrPoQVanw5PMw/TB0t5Ec4=
github.com/pelletier/go-toml/v2 v2.2.4/go.mod h1:2gIqNv+qfxSVS7cM2xJQKtLSTLUE9V8t9Stt+h56mCY=
github.com/pmezard/go-difflib v1.0.0 h1:4DBwDE0NGyQoBHbLQYPwSUPoCMWR5BEzIk/f1lZbAQM=
github.com/pmezard/go-difflib v1.0.0/go.mod h1:iKH77koFhYxTK1pcRnkKkqfTogsbg7gZNVY4sRDYZ/4=
github.com/quic-go/qpack v0.5.1 h1:giqksBPnT/HDtZ6VhtFKgoLOWmlyo9Ei6u9PqzIMbhI=
github.com/quic-go/qpack v0.5.1/go.mod h1:+PC4XFrEskIVkcLzpEkbLqq1uCoxPhQuvK5rH1ZgaEg=
github.com/quic-go/quic-go v0.54.0 h1:6s1YB9QotYI6Ospeiguknbp2Znb/jZYjZLRXn9kMQBg=
github.com/quic-go/quic-go v0.54.0/go.mod h1:e68ZEaCdyviluZmy44P6Iey98v/Wfz6HCjQEm+l8zTY=
github.com/stretchr/objx v0.1.0/go.mod h1:HFkY916IF+rwdDfMAkV7OtwuqBVzrE8GR6GFx+wExME=
github.com/stretchr/objx v0.4.0/go.mod h1:YvHI0jy2hoMjB+UWwv71VJQ9isScKT/TqJzVSSt89Yw=
github.com/stretchr/objx v0.5.0/go.mod h1:Yh+to48EsGEfYuaHDzXPcE3xhTkx73EhmCGUpEOglKo=
github.com/stretchr/testify v1.3.0/go.mod h1:M5WIy9Dh21IEIfnGCwXGc5bZfKNJtfHm1UVUgZn+9EI=
github.com/stretchr/testify v1.7.1/go.mod h1:6Fq8oRcR53rry900zMqJjRRixrwX3KX962/h/Wwjteg=
github.com/stretchr/testify v1.8.0/go.mod h1:yNjHg4UonilssWZ8iaSj1OCr/vHnekPRkoO+kdMU+MU=
github.com/stretchr/testify v1.8.1/go.mod h1:w2LPCIKwWwSfY2zedu0+kehJoqGctiVI29o6fzry7u4=
github.com/stretchr/testify v1.11.1 h1:7s2iGBzp5EwR7/aIZr8ao5+dra3wiQyKjjFuvgVKu7U=
github.com/stretchr/testify v1.11.1/go.mod h1:wZwfW3scLgRK+23gO65QZefKpKQRnfz6sD981Nm4B6U=
github.com/twitchyliquid64/golang-asm v0.15.1 h1:SU5vSMR7hnwNxj24w34ZyCi/FmDZTkS4MhqMhdFk5YI=
github.com/twitchyliquid64/golang-asm v0.15.1/go.mod h1:a1lVb/DtPvCB8fslRZhAngC2+aY1QWCk3Cedj/Gdt08=
github.com/ugorji/go/codec v1.3.0 h1:Qd2W2sQawAfG8XSvzwhBeoGq71zXOC/Q1E9y/wUcsUA=
github.com/ugorji/go/codec v1.3.0/go.mod h1:pRBVtBSKl77K30Bv8R2P+cLSGaTtex6fsA2Wjqmfxj4=
go.uber.org/mock v0.5.0 h1:KAMbZvZPyBPWgD14IrIQ38QCyjwpvVVV6K/bHl1IwQU=
go.uber.org/mock v0.5.0/go.mod h1:ge71pBPLYDk7QIi1LupWxdAykm7KIEFchiOqd6z7qMM=
golang.org/x/arch v0.20.0 h1:dx1zTU0MAE98U+TQ8BLl7XsJbgze2WnNKF/8tGp/Q6c=
golang.org/x/arch v0.20.0/go.mod h1:bdwinDaKcfZUGpH09BB7ZmOfhalA8lQdzl62l8gGWsk=
golang.org/x/crypto v0.40.0 h1:r4x+VvoG5Fm+eJcxMaY8CQM7Lb0l1lsmjGBQ6s8BfKM=
golang.org/x/crypto v0.40.0/go.mod h1:Qr1vMER5WyS2dfPHAlsOj01wgLbsyWtFn/aY+5+ZdxY=
golang.org/x/mod v0.25.0 h1:n7a+ZbQKQA/Ysbyb0/6IbB1H/X41mKgbhfv7AfG/44w=
golang.org/x/mod v0.25.0/go.mod h1:IXM97Txy2VM4PJ3gI61r1YEk/gAj6zAHN3AdZt6S9Ww=
golang.org/x/net v0.42.0 h1:jzkYrhi3YQWD6MLBJcsklgQsoAcw89EcZbJw8Z614hs=
golang.org/x/net v0.42.0/go.mod h1:FF1RA5d3u7nAYA4z2TkclSCKh68eSXtiFwcWQpPXdt8=
golang.org/x/sync v0.16.0 h1:ycBJEhp9p4vXvUZNszeOq0kGTPghopOL8q0fq3vstxw=
golang.org/x/sync v0.16.0/go.mod h1:1dzgHSNfp02xaA81J2MS99Qcpr2w7fw1gpm99rleRqA=
golang.org/x/sys v0.6.0/go.mod h1:oPkhp1MJrh7nUepCBck5+mAzfO9JrbApNNgaTdGDITg=
golang.org/x/sys v0.35.0 h1:vz1N37gP5bs89s7He8XuIYXpyY0+QlsKmzipCbUtyxI=
golang.org/x/sys v0.35.0/go.mod h1:BJP2sWEmIv4KK5OTEluFJCKSidICx8ciO85XgH3Ak8k=
golang.org/x/text v0.27.0 h1:4fGWRpyh641NLlecmyl4LOe6yDdfaYNrGb2zdfo4JV4=
golang.org/x/text v0.27.0/go.mod h1:1D28KMCvyooCX9hBiosv5Tz/+YLxj0j7XhWjpSUF7CU=
golang.org/x/tools v0.34.0 h1:qIpSLOxeCYGg9TrcJokLBG4KFA6d795g0xkBkiESGlo=
golang.org/x/tools v0.34.0/go.mod h1:pAP9OwEaY1CAW3HOmg3hLZC5Z0CCmzjAF2UQMSqNARg=
google.golang.org/protobuf v1.36.9 h1:w2gp2mA27hUeUzj9Ex9FBjsBm40zfaDtEWow293U7Iw=
google.golang.org/protobuf v1.36.9/go.mod h1:fuxRtAxBytpl4zzqUh6/eyUujkJdNiuEkXntxiD/uRU=
gopkg.in/check.v1 v0.0.0-20161208181325-20d25e280405/go.mod h1:Co6ibVJAznAaIkqp8huTwlJQCZ016jof/cbN4VW5Yz0=
gopkg.in/yaml.v3 v3.0.0-20200313102051-9f266ea9e77c/go.mod h1:K4uyk7z7BCEPqu6E+C64Yfv1cQ7kz7rIZviUmN+EgEM=
gopkg.in/yaml.v3 v3.0.1 h1:fxVm/GzAzEWqLHuvctI91KS9hhNmmWOoWu0XTYJS7CA=
gopkg.in/yaml.v3 v3.0.1/go.mod h1:K4uyk7z7BCEPqu6E+C64Yfv1cQ7kz7rIZviUmN+EgEM=
sudo -u cloud sh -c "cd /home/cloud/git/test-server; GOROOT=/usr/local/go GOHOME=/home/cloud/go /usr/local/go/bin/go install -v"
rm -f /usr/local/bin/test-server
cp -f /home/cloud/go/bin/test-server /usr/local/bin/test-server
if ! id test-server &>/dev/null; then
useradd -r -s /sbin/nologin -c 'Test web server' test-server &> /dev/null || true
fi
tee /etc/systemd/system/test-server.service << 'EOF'
[Unit]
Description=Test Web Server
[Service]
User=test-server
Group=test-server
ExecStart=/usr/local/bin/test-server
TimeoutStopSec=5s
LimitNOFILE=500000
LimitNPROC=512
PrivateTmp=true
ProtectSystem=full
ProtectHostname=true
ProtectKernelTunables=true
AmbientCapabilities=CAP_NET_BIND_SERVICE
[Install]
WantedBy=multi-user.target
systemctl daemon-reload
systemctl enable --now test-server
