Import authorities key's from another pritunl zero management
Hello Team
Is a way to import from previous pritunl the authorities of a previous pritunl management.
Because we want to install a fresh pritunl zero and we d’ont want to redeploy the pritunl authorities on all server’s
I think about dump the collection from mongo and reimport on the new one.
What do you think ?
Thanks for your feedback
Vinz
The command mongodump --uri="mongodb://<username>:<password>@<host>:<port>/pritunl-zero" --collection=authorities --out=backup will export the authorities collection. Then the command mongorestore --uri="mongodb://<username>:<password>@<host>:<port>/pritunl-zero" --collection=authorities --nsInclude="pritunl-zero.authorities" backup/pritunl-zero/authorities.bson can be used to import the collection.
Thanks Zach for the feedback
I will try this migration plan
Best regards
Hello
Little feedback to tell that all work’s as expected with @zach command line.
Thanks a lot
