Hey there!
Long story short, I’m on Windows 10, re-installed the latest client v1.3.3814.40 and after clicking “Connect” on any profile, I’m constantly getting “Reconnecting”. Restarting client, restarting Windows, re-importing profile didn’t help.
My connection is through Wi-Fi.
Really looking for some help, please, since this is blocking my work.
In the Service logs the following is printed on and on:
[2024-07-07 14:14:06][ERRO] ▶ utils: Process exec error ◆ arg=[]string(nil) ◆ cmd="C:\\Windows\\system32\\netsh.exe" ◆ error_output="" ◆ output="netsh>The filename, directory name, or volume label syntax is incorrect.\r\n\r\n\r\nnetsh>"
utils: Failed to exec 'C:\Windows\system32\netsh.exe'
exit status 1
github.com/pritunl/pritunl-client-electron/service/utils.ExecInputOutputCombindLogged
C:/Users/Cloud/go/src/github.com/pritunl/pritunl-client-electron/service/utils/proc.go:238 +0x693944
github.com/pritunl/pritunl-client-electron/service/tuntap.Configure
C:/Users/Cloud/go/src/github.com/pritunl/pritunl-client-electron/service/tuntap/tuntap.go:62 +0x7574d3
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn
C:/Users/Cloud/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1463 +0x7682cd
C:/Users/Cloud/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1364 +0x767aa7
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).Restart.func1
C:/Users/Cloud/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:4395 +0x7798da
C:/Program Files/Go/src/runtime/asm_amd64.s:1695 +0x1b1120
p.s. previous client I had installed v1.2.2653.1 was working just fine for the latest 4 years or so, till last Friday. Today it refused to show any reaction to my clicks on “Connect” - just literally nothing was happening, logs were empty. After Windows restart it began showing “Unable to communicate with helper service”, even though it was in running state in Win Services list. Restarting didn’t help. So, I decided to uninstall the client and install the latest version, and now I’m here…
