Cordial Saludo!
Si se siguen los pasos de instalación en lunux 8 de oracle no funciona, saca error en el comando: sudo dnf -y install pritunl pritunl-openvpn wireguard-tools mongodb-org
el error es el siguiente:
Problem 1: conflicting requests
- nothing provides libcrypto.so.3()(64bit) needed by pritunl-openvpn-2.6.12-1.el9.oraclelinux.x86_64 from pritunl
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by pritunl-openvpn-2.6.12-1.el9.oraclelinux.x86_64 from pritunl
- nothing provides libssl.so.3()(64bit) needed by pritunl-openvpn-2.6.12-1.el9.oraclelinux.x86_64 from pritunl
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by pritunl-openvpn-2.6.12-1.el9.oraclelinux.x86_64 from pritunl
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by pritunl-openvpn-2.6.12-1.el9.oraclelinux.x86_64 from pritunl
- nothing provides libselinux.so.1(LIBSELINUX_1.0)(64bit) needed by pritunl-openvpn-2.6.12-1.el9.oraclelinux.x86_64 from pritunl
Problem 2: package pritunl-1.32.4057.36-1.el9.oraclelinux.x86_64 from pritunl requires openvpn, but none of the providers can be installed - cannot install the best candidate for the job
Problem 3: package mongodb-org-7.0.15-1.el9.x86_64 from mongodb-org requires mongodb-org-database, but none of the providers can be installed - package mongodb-org-database-7.0.0-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.1-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.11-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.12-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.14-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.15-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.2-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.3-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.4-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.5-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.6-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.7-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.8-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- package mongodb-org-database-7.0.9-1.el9.x86_64 from mongodb-org requires mongodb-org-server, but none of the providers can be installed
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.0-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.0-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.0-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.0-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.0-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.0-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.1-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.1-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.1-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.1-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.1-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.1-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.11-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.11-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.11-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.11-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.11-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.11-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.12-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.12-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.12-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.12-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.12-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.12-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.14-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.14-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.14-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.14-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.14-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.14-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.15-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.15-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.15-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.15-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.15-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.15-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.2-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.2-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.2-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.2-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.2-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.2-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.3-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.3-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.3-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.3-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.3-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.3-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.4-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.4-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.4-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.4-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.4-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.4-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.5-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.5-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.5-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.5-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.5-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.5-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.6-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.6-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.6-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.6-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.6-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.6-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.7-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.7-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.7-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.7-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.7-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.7-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.8-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.8-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.8-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.8-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.8-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.8-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3()(64bit) needed by mongodb-org-server-7.0.9-1.el9.x86_64 from mongodb-org
- nothing provides libcrypto.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.9-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3()(64bit) needed by mongodb-org-server-7.0.9-1.el9.x86_64 from mongodb-org
- nothing provides libssl.so.3(OPENSSL_3.0.0)(64bit) needed by mongodb-org-server-7.0.9-1.el9.x86_64 from mongodb-org
- nothing provides libc.so.6(GLIBC_2.34)(64bit) needed by mongodb-org-server-7.0.9-1.el9.x86_64 from mongodb-org
- nothing provides libm.so.6(GLIBC_2.29)(64bit) needed by mongodb-org-server-7.0.9-1.el9.x86_64 from mongodb-org
(try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
