Hi all,
I’ve installed this great product.
It is possible the connection form the connected VPN users with another host on my local network without nat through the IP address of the pritunl server?.
My VPN users have assigned 10.8.0.0/24 network, some services are located in the same L2 network with IP 10.15.105.0/24. I need that the connection between both networks without nat, so if I connect from a VPN users to 10.15.105.0/24 the connection must be originated with IP of the 10.8.0.0/24 network.
This will be done with iptables -j RETURN for origin and destination networks. It is possible to deploy these rules on the pritunl server permanently, so if the red ver is restarted the rules will be activated?
Best regards,
