I have an issue with lack of internet access when connecting to the VPN.
I work on an Intel Mac, internet access does work if I disable the DNS and the gateway but that doesn’t allow me to access anything inside.
The original issue actually was that using the VPN would initially work fine but after a while I would lose internet access. I can’t connect to anything besides a few machines, DNS also being inaccessible.
I tried switching to TCP but it doesn’t work at all and using keepalive instead of ping but it didn’t help.
Moreover, after restarting the VPN multiple times I start getting socket errors that I can only make go away by restarting the whole computer (restarting the service does not help):
RequestError: Request: Client error method=GET path=/sprofile
Error: connect ENOENT /var/run/pritunl.sock
at __node_internal_captureLargerStackTrace (node:internal/errors:497:5)
at __node_internal_exceptionWithHostPort (node:internal/errors:672:12)
at PipeConnectWrap.afterConnect [as oncomplete] (node:net:1595:16)
That causes all connectivity to be lost.
The profile log looks like this:
2024-03-12 17:20:04 Opened utun device utun7
2024-03-12 17:20:04 /sbin/ifconfig utun7 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2024-03-12 17:20:04 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2024-03-12 17:20:04 /sbin/ifconfig utun7 192.168.237.6 192.168.237.6 netmask 255.255.255.0 mtu 1500 up
route: writing to routing socket: File exists
add net 192.168.237.0: gateway 192.168.237.6: File exists
2024-03-12 17:20:04 /tmp/pritunl/5a78abed73f05431-block.sh utun7 1500 0 192.168.237.6 255.255.255.0 init
add net 109.232.29.29: gateway 192.168.0.1
add net 0.0.0.0: gateway 192.168.237.1
add net 128.0.0.0: gateway 192.168.237.1
add net 1.1.1.1: gateway 192.168.237.1
dhcp-option DNS 1.1.1.1
2024-03-12 17:20:04 Initialization Sequence Completed
2024-03-12 17:20:04 Data Channel: cipher 'AES-128-GCM', peer-id: 2, compression: 'stub'
2024-03-12 17:20:04 NOTE: --mute triggered…
I talked to the person managing the VPN but they don’t have these issues, it seems to be just me.
