Hello! AFAIS the IPv6 client pool is not configurable, but always in the range fd00:… I dumped the mongodb and did not find any config options with this string, which lead me to the conclusion that the IPv6 client pool virtual network is derived from the IPv4 client pool virtual network.
I also read, that with the Premium subscription the “host” can be configured to use a Routed IPv6 Subnet, which, if configured, will be used as client pool.
In our company, we currently have VPN client pools per department. When connected to the VPN, every department has a defined IPv4 range (RFC1918) and a defined IPv6 range (public/global addresses). These networks are used in our firewall to grant access. Currently we use this setup with plain OpenVPN.
I wanted to replace that setup with Pritunl. For every department I configured a “server”, and the IPv4 client range (without NAT). That works fine. I also would like to keep the current IPv6 client ranges for every department. So I would like to configure the IPv6 pool per server, just as I configured the IPv4 pool. Is this somehow possible?
