Is it possible to limit ports
With OpenVPN we were able to limit people by service ports. Is this possible with Pritunl?
Pritunl allows you to configure various aspects of your VPN server. While it doesn’t directly limit users by service ports like OpenVPN, there are other security and configuration options you can explore.
If you want to know i can share you other options also.
I think you will have to use an external option:
But that will also limit the server it self (When using NAT on the VPN server - Default) else you will need to bridge the network for the clients and then limit the bridged ip’s.
I do not think it is an option in ether openvpn or wireguard to make that kind of limits.
