Is there a way to add a subject alternate name when setting the acme_domain field?
I use a cname to point to the acme_domain that is used to deploy Pritunl and would like to included that when Lets Encrypt makes the cert request.
The Lets Encrypt domain option can include a list of comma separated domain names.
Do you have an example? Every time I try that it always concatenates them into a single string and validation fails.
Just for reference vpn.stud in this case would be a dynamic url that gets generated and vpn.stage would be the cname. No matter how I enter them in the Domain field they always get joined together. Pretty sure the CLI command does the same thing.
[ancient-thunder-9461][2024-04-11 10:04:52,082][ERROR] Failed to get LetsEncrypt cert
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/handlers/settings.py”, line 1112, in settings_put
acme.update_acme_cert()
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/acme.py”, line 73, in update_acme_cert
cert = get_acme_cert(settings.app.acme_key, csr, cmdline)
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/acme.py”, line 45, in get_acme_cert
certificate = acmetiny.get_crt(
File “/usr/lib/pritunl/usr/lib/python3.9/site-packages/pritunl/acmetiny.py”, line 138, in get_crt
raise ValueError(“Challenge did not pass for {0}: {1}”.format(domain, authorization))
ValueError: Challenge did not pass for vpn.stud.mgmt.XXXXX.iovpn.stage.mgmt.XXXXX.io: {‘identifier’: {‘type’: ‘dns’, ‘value’: ‘vpn.stud.mgmt.XXXXX.iovpn.stage.mgmt.XXXXX.io’}, ‘status’: ‘invalid’, ‘expires’: ‘2024-04-18T10:04:49Z’, ‘challenges’: [{‘type’: ‘http-01’, ‘status’: ‘invalid’, ‘error’: {‘type’: ‘urn:ietf:params:acme:error:dns’, ‘detail’: ‘DNS problem: NXDOMAIN looking up A for vpn.stud.mgmt.XXXXXiovpn.stage.mgmt.XXXXX.io - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for vpn.stud.mgmt.XXXXX.iovpn.stage.mgmt.XXXXX.io - check that a DNS record exists for this domain’, ‘status’: 400}, ‘url’: ‘https://acme-v02.api.letsencrypt.org/acme/chall-v3/337165754037/iGq5UA’, ‘token’: ‘Z8vbt84uFGkr8huoVMikxHsAn15xntiODgXSmqIv7so’, ‘validated’: ‘2024-04-11T10:04:50Z’}]}
acme_domain = “vpn.stud.mgmt.XXXXX.iovpn.stage.mgmt.XXXXX.io”
Actually for Pritunl it is only one domain. Pritunl Zero and Pritunl Cloud have support for multiple domains but not the VPN server.
