Hi
We have one VPN isntallation, on a t3.small AWS machine using a single IP and hostname with single LE certificate.
But it host 4 servers (one for ourselves, one for controller company and another two for business partners). We’re using the Enterprise license.
Our server has one IdP (Google Workspace) configurated so we can SSO using it.
But all other 3 servers do not have option to use SSO!
AFAIK the SSO/IdP is a configuration for whole installation, not a configuration at server level.
I’d like to know if there are plans to bring this config to server level (not the installation level).
I think I could generate several instances, each one with a different IP, port, IdP, … and so on.
But it would take operational task to another level.
Our two partners have less than 10 users each one!
Our controller have hundreds of users… some of them never logged in, some have logged in last time 2 years ago.
All of this because isn’t possible to set IdP for EACH server.
Do you have a roadmap for this or a workaround with easy maintenance ?
Regards,
Jáder
