It appears that by default, any server within an organization inherits all network links associated with a use even if that user is not part of the server’s group. Is there a way to restrict this behavior?
Thank you!
Thank you!
If you’re referring to linked servers there isn’t an option to exclude routes. More advanced configurations should use pritunl-link.
No, I mean network link on user level.
If a user is part of multiple Groups then every server part of this Group/s inherits the User network link/s.
Is there a way to limit this?
It will show up on every server but it is only routed on the servers the user is actively connected to.
