No automatic client reconnection with SSO authentication
We are currently looking at changing our Pritunl VPN servers from certificate-based authentication to Azure Entra SSO authentication.
The configuration works without any issues, and we are able to authenticate successfully to the VPN using SSO.
The problem we are facing is the following: previously, with certificate-based authentication, when we added a route on the server, we need to stop the pritunl server and start it after we added the route, all the clients reconnect automatically on the pritunl server. Even if the server was restarted, adding a route was barely noticeable for users.
Now, with the SSO configuration, if I restart the server using the button in the web interface, I get the following messages on the client side:
  • Connection timed out on Pritunl_server_name (username)
  • Failed to authenticate to Pritunl_server_name (username)
After that, I am disconnected from my Pritunl client.
I also tested with the ‘Pritunl Authentication Cache’ option enabled, but I observe the same behavior.
After this disconnection, I can reconnect without any issue by simply clicking the Connect button in the Pritunl client.
My question is therefore: is it possible for clients to reconnect automatically when the SSO / Azure Entra authentication is enabled?
Thanks for your time and your work…
Eric
Check the logs in the top right of the server web console for the authentication failure reason. The cache token can expire and will not remain after the client system restarts.
Sorry for the delay, I had to run additional tests and noticed something strange.
When I click the Restart Server button (between Settings and Stop Server), I get the following message on the client:
At the same time, I see these logs in the top-right corner of the web console:
[server_name3][2026-04-27 14:21:14,128][INFO] Starting vpn server
server_id = “”
instance_id = “”
instances =
instances_count = 0
route_count = 3
network = “ipv4/16”
network6 = “ipv6/64”
ovpn_dco = false
dynamic_firewall = false
bypass_sso_auth = false
geo_sort = false
force_connect = false
sso_auth = true
route_dns = false
device_auth = false
host_id = “id_server_name3”
host_address = “ip_server_name3”
host_address6 = “ipv6_server_name3”
host_networks = [“host_network”]
cur_timestamp = “2026-04-27 14:21:14.127797”
libipt = false
[server_name3][2026-04-27 14:21:14,142][WARNING] Stopping duplicate instance, check date time sync
server_id = “”
instance_id = “69ef6f9d95cb03ff428a98a2”
[server_name4][2026-04-27 14:21:14,275][INFO] Starting vpn server
server_id = “”
instance_id = “69ef70da342fde39bc6428fa”
instances = [{“instance_id”: “”, “host_id”: “id_server_name3”, “ping_timestamp”: “2026-04-27 14:21:44.119000”}]
instances_count = 1
route_count = 3
network = “ipv4/16”
ovpn_dco = false
geo_sort = false
sso_auth = true
route_dns = false
device_auth = false
host_id = “id_server_name4”
host_address = “ip_server_name4”
host_address6 = “ipv6_server_name4”
cur_timestamp = “2026-04-27 14:21:14.275010”
libipt = false
[server_name4][2026-04-27 14:21:14,310][WARNING] Stopping duplicate instance, check date time sync
server_id = “”
instance_id = “69ef6f9d342fde39bc642072”
[server_name3][2026-04-27 14:21:22,325][INFO] Authenticating user
user_name = “username”
factors = [“azure”]
After this, the client never reconnects automatically.
If I manually click Connect in the Pritunl client, the following appears in the logs:
[server_name3][2026-04-27 14:22:19,204][INFO] Authenticating user
factors = [“azure”]
[server_name3][2026-04-27 14:22:19,213][INFO] Client authentication with sso token
org_name = “org_name”
server_name = “Pritunl_server_name”
[server_name3][2026-04-27 14:22:19,214][INFO] Client sso authentication, skipping password
[server_name3][2026-04-27 14:22:20,415][INFO] Storing authentication cache token
factors = [“azure”]
[server_name4][2026-04-27 14:22:21,303][INFO] Authenticating user
factors = [“azure”]
[server_name4][2026-04-27 14:22:21,309][INFO] Client authentication with sso token
[server_name4][2026-04-27 14:22:21,310][INFO] Client sso authentication, skipping password
BUT, If I click Stop Server (between Restart Server and Delete Server), I only get this on the client:
The client status stays stuck on “Connecting”, and no logs appear at all in the web console.
When I click Start Server, the Pritunl client briefly shows:
Failed to connect to Pritunl_server_name (username)
However, immediately after that, the connection is actually successful.
Relevant logs:
[server_name4][2026-04-27 14:24:03,376][INFO] Starting vpn server
server_id = “”
instance_id = “”
instances =
instances_count = 0
route_count = 3
network = “ip/16”
ovpn_dco = false
geo_sort = false
sso_auth = true
route_dns = false
device_auth = false
cur_timestamp = “2026-04-27 14:24:03.374531”
libipt = false
[server_name3][2026-04-27 14:24:03,374][INFO] Starting vpn server
server_id = “”
instance_id = “69ef718395cb03ff428aa592”
instances =
instances_count = 0
route_count = 3
network = “ipv4/16”
ovpn_dco = false
geo_sort = false
sso_auth = true
route_dns = false
device_auth = false
cur_timestamp = “2026-04-27 14:24:03.374061”
libipt = false
[server_name3][2026-04-27 14:24:30,666][INFO] Authenticating user
factors = [“azure”]
[server_name3][2026-04-27 14:24:30,670][INFO] Client authentication cached, skipping sso token
[server_name3][2026-04-27 14:24:30,675][INFO] Client authentication cached, skipping password
[server_name4][2026-04-27 14:24:32,837][INFO] Authenticating user
factors = [“azure”]
[server_name4][2026-04-27 14:24:32,844][INFO] Client authentication with sso token
[server_name4][2026-04-27 14:24:32,845][INFO] Client sso authentication, skipping password
So, based on these tests, my understanding is:
When adding or modifying routes (for example), I should stop the server and start it again, rather than using the Restart Server button.
The server should be stopped before modifying routes then started again. It shouldn’t allow route modifications to occur while the server is running.
