Good day. I installed it, everything went without errors. Then a window appears where I need to insert the key. I do it through the console, then insert it. After pressing the button, an error is written.
Check /var/log/pritunl.log for the error then run sudo pritunl reconfigure to restart the configuration. If the database is local verify the service is running with sudo systemctl status mongod.
Thank you, I’ll try it now
