Old versions missing in dnf repos after the latest client releases
I noticed after pritunl-client-1.4.477.47-1 was released all the older releases disappeared from the repo Index of /stable/yum/oraclelinux/8
only the latest 1.3 and 1.4 releases are available.
even the rocky8 repo ( Index of /stable/yum/rockylinux/8 ) only has a single RPM in it now - the 1.4.477.47 client
we version pin pritunl-client across our fleet so now new builds are failing during the install of pritunl-client
A lot of releases from all the packages were removed to reduce the overall size of the repo. The latest v1.3 release is well tested and the v1.4 release brings a lot of improvements. Both should be ready to use. There may be some compatibility issues with the CLI API in v1.4 due to the redesign and addition of the TUI.
Rocky Linux had been removed entirely a while ago due to issues with the Docker images. The documentation substituted Oracle Linux which is a very close RHEL clone to Rocky Linux. It is now back in the pacur build system and is being added to builds. As new builds go through Rocky Linux builds for all the packages will be available again.
