Hi, since there is no pritunl-client app for Android I installed openvpnconnect and imported the profile from the .ovpn FILE and it works fine for me. With the same application I’m trying to connect to VPN but using the URL function by inserting the link of my user available on the pritunl panel (I’ve tried them all) but after asking me for credentials it gives me an error and doesn’t connect. Solutions?
The URL from Pritunl will only work with the Pritunl Client available on macOS, Windows and Linux.
…and for android? There is a solution?
Pritunl Client for Android ? Why is it not available yet?
Those URLs will only work on the Pritunl Client. For other clients import the file.
