Currently, in the pritunl client there is an option under settings to “Disable Default Gateway”. This is useful if the VPN server is configured for a “full” tunnel. In this case, a user can choose this option, which will enable a split tunnel.
Our VPN server is configured for a split tunnel by default (i.e. it does not route the default route 0.0.0.0/0 vi the tunnel). However, there are cases in which a user may want to use a full tunnel. Is there a way to enable a full tunnel via the client even though the server is setup for split tunneling by default?
