Is it passible to use normal long and complicated passwords for VPN users with 2FA instead of just digits PIN with 2FA?
Thank you in advance.
Running sudo pritunl set user.pin_digits_only false will allow using other characters.
Dear zach,
Thank you! It’s work for me!
