Hii, I’m using pritunl-client in my ubuntu 20.04 instance, before all works fine, but last night my client can’t connect to vpn, but if install from my mac just working fine, here is the logs
Options error: --up script fails with ‘/tmp/pritunl/sbxoutv3z9e17awc-up.sh’: Permission denied (errno=13)
Options error: Please correct this error.
Use --help for more information
Can someone help please, i have tried to reimport the profile, update and downgrade the client version, restart the client, and nothing works.
[2024-04-04 07:17:53][INFO] ▶ profile: Disconnected ◆ profile_id="vabzjdi8ho9gvt8xthfokdukk5avlbrf"
[2024-04-04 07:17:53][INFO] ▶ profile: Connecting ◆ device_auth=false ◆ disable_dns=false ◆ =
Get "": dial tcp: lookup gaara.com on 127.0.0.53:53: no such host
Run sudo rm -rf /tmp/pritunl directory and run sudo systemctl restart pritunl-client. Also run sudo aa-status -r to check the status of AppArmor if this has been configured it may be blocking access.
Hi @zach i have remove the /tmp/pritunl directory, and still get the issues, for sudo aa-status -r i got this
/usr/sbin/aa-status -r
Error: Invalid command.
Usage: /usr/sbin/aa-status [OPTIONS]
Displays various information about the currently loaded AppArmor policy.
OPTIONS (one only):
--enabled returns error code if AppArmor not enabled
--profiled prints the number of loaded policies
--enforced prints the number of loaded enforcing policies
--complaining prints the number of loaded non-enforcing policies
--json displays multiple data points in machine-readable JSON format
--pretty-json same data as --json, formatted for human consumption as well
--verbose (default) displays multiple data points about loaded policy set
--help this message
[2024-04-04 17:18:28][ERRO] ▶ profile: Failed to sync system profile ◆ profile_id="jryrrfsykyfiwlbuxvedklu4sp7hmnj0"
profile: Bad status 403 code from server
github.com/pritunl/pritunl-client-electron/service/sprofile.(*Sprofile).syncProfile
/pacur_build/src/pritunl-client-electron-1.2.3145.98/service/sprofile/sprofile.go:443 +0x928e54
github.com/pritunl/pritunl-client-electron/service/sprofile.(*Sprofile).Sync
/pacur_build/src/pritunl-client-electron-1.2.3145.98/service/sprofile/sprofile.go:486 +0x93d3b1
/pacur_build/src/pritunl-client-electron-1.2.3145.98/service/profile/profile.go:1164 +0x93d1d1
github.com/pritunl/pritunl-client-electron/service/profile.SyncSystemProfiles.func1
/pacur_build/src/pritunl-client-electron-1.2.3145.98/service/profile/utils.go:385 +0x94a3ea
