Pritunl Client v1.3.4051.36 has been released. This release includes rewritten connection management code, new themes, full Windows ARM support and bundled WireGuard on macOS.
New Connection Management Code
The previous connection management code had several issues causing the connection state to get stuck, connection issues and errors that would crash the background service. The new code significantly improves the reliability of the connection management and improved logging to fix future issues.
New Themes
There are now 2 styles of themes each with a light and dark variant. These themes can be changed from the top right menu.
Full Windows ARM Support
All components of the client are now built for both Windows x86 and ARM. Similar to the macOS ARM support this does result in the installer size doubling. The installer will install the components for the matched system architecture.
Bundled WireGuard on macOS
The macOS build now comes bundled with both OpenVPN and WireGuard. Both OpenVPN and WireGuard connections will now be available without any additional requirements. The Windows client will still require installing the WireGuard client separately.
