Pritunl Client v1.3.4059.45
This version throws an error while installing. while installing “pritunl-service.exe” an access not allowed error—latest 24H2 Windows 11 version.
MacOS 15.1 - do not look to be a problem on MacOS 14.*
Update: Looks to be related to New connection behavior with macOS client v1.3.4059.45
We have an other mac error, pritunl treat ipv4’s as ipv6
192.0.2.2:64924 [65c33bc46e8a461dec895329] Peer Connection Initiated with [AF_INET6]::ffff:192.0.2.2:64924
In the client it also shows as ::ffff:198.51.100.2
Client logs:
2024-10-28 11:27:01 Unrecognized option or missing or extra parameter(s) in /tmp/pritunl/574e601d4379796f:25: block-outside-dns (2.6.12)
2024-10-28 11:27:01 OpenVPN 2.6.12 arm-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH/RECVDA] [AEAD]
2024-10-28 11:27:01 library versions: OpenSSL 3.3.2 3 Sep 2024, LZO 2.10
2024-10-28 11:27:01 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2024-10-28 11:27:01 TCP/UDP: Preserving recently used remote address: [AF_INET6]::ffff:198.51.100.2:18273
2024-10-28 11:27:01 UDPv6 link local: (not bound)
2024-10-28 11:27:01 UDPv6 link remote: [AF_INET6]::ffff:198.51.100.2:18273
2024-10-28 11:27:01 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
2024-10-28 11:27:01 VERIFY SCRIPT OK: depth=1, O=65b8f866482b71a658c0c0e1, CN=65b8f866482b71a658c0c0e6
2024-10-28 11:27:01 NOTE: --mute triggered...
2024-10-28 11:27:01 8 variation(s) on previous 3 message(s) suppressed by --mute
2024-10-28 11:27:01 [65b8f869482b71a658c0c0f4] Peer Connection Initiated with [AF_INET6]::ffff:198.51.100.2:18273
2024-10-28 11:27:02 WARNING: You have specified redirect-gateway and redirect-private at the same time (or the same option multiple times). This is not well supported and may lead to unexpected results
2024-10-28 11:27:02 Options error: Unrecognized option or missing or extra parameter(s) in [PUSH-OPTIONS]:11: redirect-gateway-ipv6 (2.6.12)
2024-10-28 11:27:02 GDG6: problem writing to routing socket: No such process (errno=3)
2024-10-28 11:27:02 ROUTE6: IPv6 route overlaps with IPv6 remote address, but could not determine IPv6 gateway address + interface, expect failure
2024-10-28 11:27:02 Opened utun device utun4
2024-10-28 11:27:02 /sbin/ifconfig utun4 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2024-10-28 11:27:02 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2024-10-28 11:27:02 /sbin/ifconfig utun4 198.18.12.7 198.18.12.7 netmask 255.255.252.0 mtu 1500 up
add net 198.18.12.0: gateway 198.18.12.7
2024-10-28 11:27:02 /sbin/ifconfig utun4 inet6 fd00:c612:c00:0:198:18:12:7/64 mtu 1500 up
route: writing to routing socket: File exists
add net fd00:c612:c00::: gateway utun4: File exists
2024-10-28 11:27:02 /tmp/pritunl/574e601d4379796f-block.sh utun4 1500 0 198.18.12.7 255.255.252.0 init
add net 0.0.0.0: gateway 198.18.12.1
add net 128.0.0.0: gateway 198.18.12.1
add host 2001:db8:b270::12e: gateway utun4
add host 2001:db8:b270::12f: gateway utun4
add net 2000::: gateway utun4
add net ::: gateway utun4
add net 3000::: gateway utun4
add net fc00::: gateway utun4
dhcp-option DNS 2001:db8:b270::12e
dhcp-option DNS 2001:db8:b270::12f
SET  2001:db8:b270::12e 2001:db8:b270::12f ON USB 10/100/1000 LAN
SET  2001:db8:b270::12e 2001:db8:b270::12f ON Dell Universal Dock D6000
SET  2001:db8:b270::12e 2001:db8:b270::12f ON AX88179A
SET  2001:db8:b270::12e 2001:db8:b270::12f ON Wi-Fi
SET  2001:db8:b270::12e 2001:db8:b270::12f ON Thunderbolt Bridge
SET  2001:db8:b270::12e 2001:db8:b270::12f ON iPhone USB
2024-10-28 11:27:03 Initialization Sequence Completed
2024-10-28 11:27:03 Data Channel: cipher 'AES-256-GCM', peer-id: 3, compression: 'stub'
2024-10-28 11:27:03 NOTE: --mute triggered...
2024-10-28 11:29:14 2 variation(s) on previous 3 message(s) suppressed by --mute
2024-10-28 11:29:14 [65b8f869482b71a658c0c0f4] Inactivity timeout (--ping-exit), exiting
2024-10-28 11:29:14 /tmp/pritunl/574e601d4379796f-down.sh utun4 1500 0 198.18.12.7 255.255.252.0 init
delete net 0.0.0.0: gateway 198.18.12.1
delete net 128.0.0.0: gateway 198.18.12.1
delete host 2001:db8:b270::12e: gateway utun4
delete host 2001:db8:b270::12f: gateway utun4
delete net 2000::: gateway utun4
delete net ::: gateway utun4
delete net 3000::: gateway utun4
delete net fc00::: gateway utun4
2024-10-28 11:29:17 Closing TUN/TAP interface
2024-10-28 11:29:17 /sbin/route delete -inet6 fd00:c612:c00:0:198:18:12:7
delete host fd00:c612:c00:0:198:18:12:7
2024-10-28 11:29:17 /tmp/pritunl/574e601d4379796f-block.sh utun4 1500 0 198.18.12.7 255.255.252.0 init
2024-10-28 11:29:17 SIGTERM[soft,ping-exit] received, process exiting
2024-10-28 11:29:24 Unrecognized option or missing or extra parameter(s) in /tmp/pritunl/574e601d4379796f:25: block-outside-dns (2.6.12)
2024-10-28 11:29:24 OpenVPN 2.6.12 arm-apple-darwin [SSL (OpenSSL)] [LZO] [PKCS11] [MH/RECVDA] [AEAD]
2024-10-28 11:29:24 library versions: OpenSSL 3.3.2 3 Sep 2024, LZO 2.10
2024-10-28 11:29:24 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2024-10-28 11:29:24 TCP/UDP: Preserving recently used remote address: [AF_INET6]2001:db8:b291::101:18273
2024-10-28 11:29:24 UDPv6 link local: (not bound)
2024-10-28 11:29:24 UDPv6 link remote: [AF_INET6]2001:db8:b291::101:18273
2024-10-28 11:29:28 Server poll timeout, restarting
2024-10-28 11:29:28 SIGUSR1[soft,server_poll] received, process restarting
2024-10-28 11:29:28 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2024-10-28 11:29:28 TCP/UDP: Preserving recently used remote address: [AF_INET6]2001:db8:b291::101:18273
2024-10-28 11:29:28 UDPv6 link local: (not bound)
2024-10-28 11:29:28 UDPv6 link remote: [AF_INET6]2001:db8:b291::101:18273
2024-10-28 11:29:33 Server poll timeout, restarting
(Using IPv4 Documentation range 192.0.2.0/24 and 198.51.100.0/24 as sample ip’s)
