Pritunl client is getting disconnected after authenticating with sso.
Let me know if any quick fix or workaround for below error.
User is running windows 8.1
[2024-02-20 14:38:47][INFO] ▶ main: Service starting ◆ version="1.3.3441.64"
[2024-02-20 14:39:43][INFO] ▶ profile: Connecting ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ mode="ovpn" ◆ profile_id="5fc0a2722b90f190" ◆ reconnect=true ◆ sso_auth=true
[2024-02-20 14:39:59][ERRO] ▶ utils: Process exec error ◆ arg=[]string{"create", "--name", "Pritunl 1"} ◆ cmd="C:\\Program Files (x86)\\Pritunl\\tuntap\\tapctl.exe" ◆ output="tap_create_adapter: DiInstallDevice failed\r\nError 0xe0000203\r\ntap_create_adapter: SetupDiCallClassInstaller(DIF_REMOVE) failed\r\nError 0xe0000204\r\nCreating TUN/TAP adapter failed (error 0xe0000203).\r\n"
utils: Failed to exec 'C:\Program Files (x86)\Pritunl\tuntap\tapctl.exe'
exit status 1
github.com/pritunl/pritunl-client-electron/service/utils.ExecCombinedOutputLogged
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/utils/proc.go:368 +0x90c78b
github.com/pritunl/pritunl-client-electron/service/tuntap.Resize
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/tuntap/tuntap.go:154 +0x92b258
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).startOvpn
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1306 +0x93d74e
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1253 +0x93c6e4
github.com/pritunl/pritunl-client-electron/service/handlers.profilePost.func1
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/handlers/profile.go:99 +0x95536b
	C:/Program Files/Go/src/runtime/asm_amd64.s:1594 +0x4671e0
[2024-02-20 14:39:59][ERRO] ▶ utils: Process exec error ◆ arg=[]string{"delete", "Pritunl 1"} ◆ cmd="C:\\Program Files (x86)\\Pritunl\\tuntap\\tapctl.exe" ◆ output="get_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\n\"Pritunl 1\" adapter not found.\r\n"
exit status 1
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/tuntap/tuntap.go:161 +0x92b306
[2024-02-20 14:40:00][ERRO] ▶ utils: Process exec error ◆ arg=[]string{"create", "--name", "Pritunl 1"} ◆ cmd="C:\\Program Files (x86)\\Pritunl\\tuntap\\tapctl.exe" ◆ output="tap_create_adapter: DiInstallDevice failed\r\nError 0xe0000203\r\ntap_create_adapter: SetupDiCallClassInstaller(DIF_REMOVE) failed\r\nError 0xe0000204\r\nCreating TUN/TAP adapter failed (error 0xe0000203).\r\n"
exit status 1
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/tuntap/tuntap.go:170 +0x92b386
[2024-02-20 14:40:00][INFO] ▶ profile: Disconnecting ◆ profile_id="5fc0a2722b90f190"
[2024-02-20 14:40:00][INFO] ▶ profile: Disconnected ◆ profile_id="5fc0a2722b90f190"
[2024-02-20 14:41:31][INFO] ▶ main: Service starting ◆ version="1.3.3441.64"
[2024-02-20 14:41:49][INFO] ▶ profile: Connecting ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ mode="ovpn" ◆ profile_id="5fc0a2722b90f190" ◆ reconnect=true ◆ sso_auth=true
[2024-02-20 14:41:49][WARN] ▶ profile: Request ovpn connection error
profile: Request put error
Post "https://[2406:da1a:fb6:d600:1309:dd21:2aa1:2518]/key/ovpn/63bd408005c205ac0ebde2df/63ece67805c205ac0ee02f12/63bd417305c205ac0ebde3cd": dial tcp [2406:da1a:fb6:d600:1309:dd21:2aa1:2518]:443: connectex: A socket operation was attempted to an unreachable network.
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).reqOvpn
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2131 +0x943039
github.com/pritunl/pritunl-client-electron/service/profile.(*Profile).openOvpn
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1819 +0x93fe64
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:1270 +0x93d472
[2024-02-20 14:42:04][INFO] ▶ profile: Disconnecting ◆ profile_id="5fc0a2722b90f190"
[2024-02-20 14:42:04][INFO] ▶ profile: Disconnected ◆ profile_id="5fc0a2722b90f190"
[2024-02-20 14:42:04][WARN] ▶ profile: Request ovpn connection error
Post "https://tunl.instahyre.com/key/ovpn_wait/63bd408005c205ac0ebde2df/63ece67805c205ac0ee02f12/63bd417305c205ac0ebde3cd/": context canceled
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2152 +0x943347
	C:/Users/Windows/go/src/github.com/pritunl/pritunl-client-electron/service/profile/profile.go:2211 +0x9436e4
[2024-02-20 14:42:04][INFO] ▶ profile: Connecting ◆ disable_gateway=false ◆ dynamic_firewall=false ◆ mode="ovpn" ◆ profile_id="5fc0a2722b90f190" ◆ reconnect=true ◆ sso_auth=true
[2024-02-20 14:42:22][ERRO] ▶ utils: Process exec error ◆ arg=[]string{"create", "--name", "Pritunl 1"} ◆ cmd="C:\\Program Files (x86)\\Pritunl\\tuntap\\tapctl.exe" ◆ output="tap_create_adapter: DiInstallDevice failed\r\nError 0xe0000203\r\ntap_create_adapter: SetupDiCallClassInstaller(DIF_REMOVE) failed\r\nError 0xe0000204\r\nCreating TUN/TAP adapter failed (error 0xe0000203).\r\n"
exit status 1
[2024-02-20 14:42:22][ERRO] ▶ utils: Process exec error ◆ arg=[]string{"delete", "Pritunl 1"} ◆ cmd="C:\\Program Files (x86)\\Pritunl\\tuntap\\tapctl.exe" ◆ output="get_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\nget_net_adapter_guid: SetupDiOpenDevRegKey failed\r\nError 0xe0000204\r\n\"Pritunl 1\" adapter not found.\r\n"
exit status 1
exit status 1
[2024-02-20 14:42:23][INFO] ▶ profile: Disconnecting ◆ profile_id="5fc0a2722b90f190"
[2024-02-20 14:42:23][INFO] ▶ profile: Disconnected ◆ profile_id="5fc0a2722b90f190"
