[EU_POP][2023-04-04 01:25:16,720][ERROR] Error in transaction runner thread
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/runners/transaction.py”, line 21, in _check_thread
for doc in collection.find(spec).sort(‘priority’):
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/cursor.py”, line 1238, in next
if len(self.__data) or self._refresh():
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/cursor.py”, line 1130, in _refresh
self.__session = self.__collection.database.client._ensure_session()
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py”, line 1935, in _ensure_session
return self.__start_session(True, causal_consistency=False)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py”, line 1883, in __start_session
server_session = self._get_server_session()
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py”, line 1921, in _get_server_session
return self._topology.get_server_session()
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/topology.py”, line 520, in get_server_session
session_timeout = self._check_session_support()
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/topology.py”, line 499, in _check_session_support
self._select_servers_loop(
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/topology.py”, line 218, in _select_servers_loop
raise ServerSelectionTimeoutError(
pymongo.errors.ServerSelectionTimeoutError: 10.10.0.102:27017: timed out, Timeout: 30.0s, Topology Description: <TopologyDescription id: 642aaa99d4f6874dbb1278d4, topology_type: Single, servers: [<ServerDescription (‘10.10.0.102’, 27017) server_type: Unknown, rtt: None, error=NetworkTimeout(‘10.10.0.102:27017: timed out’)>]>
[EU_POP][2023-04-04 01:25:18,221][ERROR] Error in tasks run thread
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/runners/task.py”, line 56, in run_thread
tsk = task_cls(id=run_id, upsert=True)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/mongo/object.py”, line 27, in new
mongo_object.load(doc=doc, spec=spec, fields=fields)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/mongo/object.py”, line 74, in load
doc = self.collection.find_one(spec, list(fields))
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 1328, in find_one
for result in cursor.limit(-1):
[EU_POP][2023-04-04 01:25:20,222][ERROR] Settings check failed
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/runners/settings.py”, line 13, in _check
settings.reload_mongo()
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/settings/settings.py”, line 109, in reload_mongo
for doc in self.collection.find():
[EU_POP][2023-04-04 01:25:22,723][ERROR] Failed to push vpn output
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/server/instance.py”, line 912, in _openvpn_stdout
self.server.output.push_output(line.decode())
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/server/output.py”, line 60, in push_output
self.collection.insert({
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 3339, in insert
return self._insert(doc_or_docs, not continue_on_error,
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 620, in _insert
return self._insert_one(
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 609, in _insert_one
self.__database.client._retryable_write(
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py”, line 1551, in _retryable_write
with self._tmp_session(session) as s:
File “/usr/lib/python3.8/contextlib.py”, line 113, in enter
return next(self.gen)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py”, line 1948, in _tmp_session
s = self._ensure_session(session)
server_id = “6406043fc0dee1812bc4323f”
[EU_POP][2023-04-04 01:25:38,230][ERROR] Error in host keep alive update
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/runners/host.py”, line 123, in _keep_alive_thread
settings.local.host.collection.update({
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 3371, in update
return self._update_retryable(
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 877, in _update_retryable
return self.__database.client._retryable_write(
host_id = “2f37d57a9fac424f92a15a785c3be17a”
host_name = “EU_POP”
[EU_POP][2023-04-04 01:25:45,733][ERROR] Error in task check thread
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/runners/task.py”, line 78, in check_thread
for task_item in task.iter_tasks(spec):
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/task.py”, line 110, in iter_tasks
for doc in Task.collection.find(spec or {}):
[EU_POP][2023-04-04 01:25:46,235][ERROR] Error in log runner thread
File “/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/runners/logger.py”, line 32, in _logger_runner_thread
collection.insert(msg_docs)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/collection.py”, line 656, in _insert
blk.execute(write_concern, session=session)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/bulk.py”, line 533, in execute
return self.execute_command(generator, write_concern, session)
File “/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/bulk.py”, line 361, in execute_command
with client._tmp_session(session) as s:
[EU_POP][2023-04-04 01:25:47,234][ERROR] Error in transaction runner thread
[EU_POP][2023-04-04 01:25:48,735][ERROR] Error in tasks run thread
