web interface is not available, ports are open
all services are running
I attach prutinl logs
ubuntu 20.04 LTS
root@vps25095:~# pritunl logs
tcmsg: [Errno 2] No such file or directory: '/proc/net/psched'
the tc subsystem functionality is limited
[undefined][2022-08-30 17:26:50,005][ERROR] Pritunl setup failed
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/setup/__init__.py", line 78, in setup_db
setup_mongo()
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/setup/mongo.py", line 342, in setup_mongo
database = client.get_default_database()
File "/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py", line 2144, in get_default_database
raise ConfigurationError(
pymongo.errors.ConfigurationError: No default database name defined or provided.
File "/usr/bin/pritunl", line 33, in <module>
sys.exit(load_entry_point('pritunl==1.30.3236.80', 'console_scripts', 'pritunl')())
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/__main__.py", line 412, in main
setup.setup_db()
setup_mongo()
/var/log/pritunl.log
root@vps25095:~# nano /var/log/pritunl.log
GNU nano 4.8 /var/log/pritunl.log
[undefined][2022-08-30 16:57:57,196][INFO] Starting setup server
[undefined][2022-08-30 16:57:57,198][INFO] Generating setup server ssl cert
[undefined][2022-08-30 16:59:30,449][ERROR] Pritunl setup failed
setup_mongo()
File "/usr/lib/pritunl/lib/python3.8/site-packages/pritunl/setup/mongo.py", line 327, in setup_mongo
client = pymongo.MongoClient(
File "/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/mongo_client.py", line 680, in __init__
seeds.update(uri_parser.split_hosts(entity, port))
File "/usr/lib/pritunl/lib/python3.8/site-packages/pymongo/uri_parser.py", line 359, in split_hosts
raise ConfigurationError("Empty host "
pymongo.errors.ConfigurationError: Empty host (or extra comma in host list).
[undefined][2022-08-30 17:02:15,575][ERROR] Pritunl setup failed
setup_mongo()
[undefined][2022-08-30 17:02:26,818][INFO] Stopping server
[undefined][2022-08-30 17:02:40,092][INFO] Starting setup server
[undefined][2022-08-30 17:02:40,094][INFO] Generating setup server ssl cert
[undefined][2022-08-30 17:02:54,152][ERROR] Pritunl setup failed
setup_mongo()
[undefined][2022-08-30 17:04:46,599][ERROR] Setup web server process exited unexpectedly
[undefined][2022-08-30 17:04:46,600][INFO] Stopping server
